Tires 17" On Rd1 ?
Old Mar 12, 2009 | 04:26 AM
shotik's Avatar
hello it is possible to make RD1 205/45 R17? 8j wheels et35
without modification and without reducing
Old Mar 12, 2009 | 08:07 AM
purpletib's Avatar
Vehicle: 2000/Hyundai/Tiburon
Depends on if you have captive rotors and what the offset is. You should be fine with that size otherwise. It is only slightly bigger than stock.
Old Mar 12, 2009 | 08:58 AM
why the hell would you put a 205 on a 8" wheel? the tire would be all stretched and retarded looking.
i had 205s on my 8" wheels on my srt for like a week and then bought wider tires.
i dont think a 8" wheel with a 35 offset will work on a tib unless your on stock suspension.
but if your going to get a 205 tire, get a 7" wide wheel to match the tire
Old Mar 14, 2009 | 11:11 PM
Denisst99's Avatar
215/40/17 does fit very well
Old Mar 15, 2009 | 08:46 PM
98tibby98's Avatar
^^^I agree, that's what I had on my tib and they fit great!
Old Mar 15, 2009 | 09:15 PM
UrS0NvS's Avatar
7.5" in terms of width of wheel is the most i would ever go.
I run 205/40/17's on a 17x7.5" rim with offset of 45.
if you can find a rim that is 17 x7 with a offset of 40 running a 205/40/17 is what the norm is i think done on the tiburon. at least, that is what i normally see and is known to work the best.
even two people with the same wheel tire combo, one will have a problem with rubbing, the other won't. it never seems to amaze me some of the querky shit we find with these tiburon's sometimes.
Old Mar 16, 2009 | 05:01 AM
Tibbi's Avatar
I have a 17x7 with a 205/40 and running stock equipment, but the offset is 38mm. Still I haven't had any adverse effects of the extra 2mm or thinner tires. I wanted 215's but the cost was almost double what I paid. This far though I have no complaints.
