Theoretically
Old Mar 22, 2012 | 06:58 PM
wheel_of_steel's Avatar
Default Theoretically
What if you were to weld plate steel onto your rear sway bar to increase the roll stiffness? Would it even work? I guess it would have to be pretty springy steel.
Just sayin, if you wanted to improve the handling for free, or had a spare sway bar lying around, it would be a fun experiment.
Old Mar 22, 2012 | 07:22 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
just change out your end links to a solid piece. That will stiffen things up a little.
Old Mar 22, 2012 | 08:32 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
sway bars are often heat treated and i believe they're made of a special type of spring steel (vanadium)-... which is nearly impossible to weld.
most likely it'd do way more harm than good.
Old Mar 23, 2012 | 01:24 AM
300D50's Avatar
Best bet is to double-up on sway bars.
There are kits for some other imports that have double-bushings and special end-link brackets to hold a second factory/aftermarket bar to reduce roll.
Old Apr 18, 2012 | 08:57 PM
Tak82's Avatar
Vehicle: 1997 RD 4-door
wouldn't the twisting break the welds?
you're talking about welding a fixed piece of metal on a metal beam that twists from lateral twisting?
Old Apr 18, 2012 | 09:31 PM
I was thinking that this would be one of the bigger problems. I'd say the plate would just crack off as a whole. Also heat treating spring steel = ?
Old Apr 18, 2012 | 09:35 PM
300D50's Avatar
No welding...
Basic idea is a bracket that both bars bolt to, then the endlink bolts to the bracket and the knuckle.
