Tenzo R Shu 4's
Old Apr 7, 2003 | 02:53 AM
Ru-E's Avatar
Default Tenzo R Shu 4's
Does anyone have them on there tib?
Guy I'm buying them from said it might not fit a hyundai cause of those nuts that are between the bolts....is there a way to ignore that?
Old Apr 7, 2003 | 11:54 AM
tiburon422's Avatar
yea i have them on my tib. You have to remove those scews. the shu-4s dont have cavities. I removed the screws but I get a little shaking from the steering for some reason. Not sure what is causiing my steering wheel to shake.
Old Apr 7, 2003 | 12:46 PM
phorq's Avatar
those screws in the hub are for manufacuring purposes only. don't worry about removing them. most aftermarket wheels don't have cavities for them.
422... chances are you need a re-balancing or alignmet to get rid of that shake. i really think there's little-to-no chance it's from the removal of those screws.
Old Apr 7, 2003 | 01:03 PM
Ru-E's Avatar
phorq:
So whats the big deal about captive rotors? Everyone does swaps and such when all you can do is remove the nuts? Thats weird.....are you sure? So if I remove those nuts then I won't have a problem at all eh....I will be able to fit any rim I want?
Old Apr 7, 2003 | 01:12 PM
Hootie's Avatar
Ru-E:
No, no, no. On captive rotors you CANNOT remove the 4, hex-head bolts. They hold the assembly in place. On NON-CAPTIVE rotors, you can remove the 4 philips-head style screws on the hub because they're not attached to anything.
Old Apr 7, 2003 | 01:19 PM
Ru-E's Avatar
Hootie:
Ru-E:
SO how do I know which one I have?
Old Apr 7, 2003 | 02:34 PM
Hootie's Avatar
Ru-E:
Take off wheel.
Look at hub.
If you see 4-HEX HEAD STYLE bolts then you have captive rotors. Also, 98 and earlier Tiburons have them.
If you see 4-PHILLIPS HEAD STYLE screws, then you have non-captive rotors. Also, 99 and newer Tiburons have them..
BTW, please update your signature. wink
[ April 07, 2003, 09:35 PM: Message edited by: Hootie ]
Old Apr 7, 2003 | 08:01 PM
phorq's Avatar
whoah whoah, sorry bout that, i thought you were talking about non-captive rotors... eek. my bad suicide i'll keep my yap shut before i cause some badness.
Old Apr 8, 2003 | 11:08 AM
Ru-E's Avatar
From doing some reading I heard you can
A) put spacers on.....(I think I'm going with this option)
cool.gif do a brake swap with a 99 tib....hmmmm I work in selling automotive parts.....so lets say I get a rotor from a 99 Tiburon....then that means I'm done with captive rotors?
by the way I checked today......they are hex bolts....so yah I got captives.....DAMN!
