strut tower brace
Old Dec 16, 2001 | 10:59 PM
Iago's Avatar
A related question....anyone know what torque the bolts connecting the brackets to the aluminum brace should be tightened to?
Old Dec 17, 2001 | 01:06 AM
skierd's Avatar
Vehicle: 1997 accent L
Originally posted by Brendan:
heres the pic.
So THATS what that thingy is, a knock sensor. Why the hell is it up there, and not closer to engine?
Old Dec 17, 2001 | 01:19 AM
That is not a knock sensor, it is an inertia sensor. The Knock sensor is mounted on the engine.
The ECU uses the inertia sensor to tell when you just hit a bump vs the engine detonating.
See Iago's post above for the full detailed description.
[ December 17, 2001: Message edited by: Random ]
Old Dec 17, 2001 | 01:24 AM
Brendan's Avatar
OOPs time to make some corrections rolleyes.gif actually that inertia sensor is also a knock sensor, but for a different kind of knock. My bad I have to learn not to trust hma diagrams too much.
Old Dec 17, 2001 | 02:31 AM
Iago's Avatar
Originally posted by Iago:
The sensor on the tower brace is actually a comparison sensor for the ECU. This one is listening to the ambient road noise being transmitted through the suspension to the body frame, engine, and everything else connected to it. The ECU uses this as a filter against what the primary knock sensor on the engine block is reading. When you hit a seam in the road, both sensors are going to pick up the "thump." The ECU sees that both sensors registered the noise, and can ignore it because it now knows the engine wasn't knocking. If the engine *was* knocking, then only the sensor on the block would pick up the noise, and then the ECU could respond accordingly.
::SIGH:: rolleyes.gif
Old Dec 18, 2001 | 07:02 AM
Iago's Avatar
Bump.
Old Dec 18, 2001 | 09:05 AM
Originally posted by Random:
Yes, you need to torque down the bolts on the strut tower to 29-36 ft lbs.
*sigh*
no no it needs 45 NM, oh wait that is 29-36 ft-lbs, never mind.
*double sigh*
[ December 18, 2001: Message edited by: Random ]
