strut tower brace
Old Dec 12, 2001 | 12:10 PM
shock6791's Avatar
Default strut tower brace
Well, I just got my tower brace from shark racing and I was wondering if there is anything I need to worry about during the install? Also is there a certain amount I have to torque the bolts on the strut tower?
Old Dec 12, 2001 | 01:19 PM
It's a pretty standard and easy install. Just be sure to leave your knock sensor mounted in the same as it was before you took it off. You'll have to either relocate it, or shave a small part of the metal off to get it to fit. This sensor is the little square sensor that sits on the strut tower on the driver's side. If you mount it any other way than the way it sits now, then you'll lose performance. wink.gif
Old Dec 12, 2001 | 01:44 PM
Yes, you need to torque down the bolts on the strut tower to 29-36 ft lbs.
Old Dec 13, 2001 | 07:50 AM
Brendan's Avatar
no no it needs 45 NM, oh wait that is 29-36 ft-lbs, never mind.
Old Dec 14, 2001 | 12:23 AM
Y2KTIBLTD's Avatar
Lo&Show, Random Is that true about moving the knock sensor?! eek.gif I've been running mine like that for quite a while now and it seemed to run ok. Could someone please take a picture of it how it's supposed to look so I can change mine. Thanks for your help!
Old Dec 14, 2001 | 12:30 AM
KayJai's Avatar
Just as long as you have it in the same upright position you should be fine. I Jerry rigged a washer and put it behind the strutbar (cuz mine is from PPSonline, not SR, and the knock sensor wont fit, unless you take a huge chunk outta the bar) by the brake fluid or PS fluid thing, works fine, mine faces the same way, and sits the same, and is still technically on the strut tower, just moved back. I think I should be fine...
Maybe the other guys can shed some more light on it.
Old Dec 14, 2001 | 01:31 AM
Iago's Avatar
Don't know about that "must be upright" statement, KayJai...I haven't had any problems with mine being mounted vertically.
The sensor on the tower brace is actually a comparison sensor for the ECU. This one is listening to the ambient road noise being transmitted through the suspension to the body frame, engine, and everything else connected to it. The ECU uses this as a filter against what the primary knock sensor on the engine block is reading. When you hit a seam in the road, both sensors are going to pick up the "thump." The ECU sees that both sensors registered the noise, and can ignore it because it now knows the engine wasn't knocking. If the engine *was* knocking, then only the sensor on the block would pick up the noise, and then the ECU could respond accordingly.
So long as you have this strut-tower knock sensor located on a flat surface that will allow it to read road noise, it will work fine. I have mine mounted on the metal around the strut tower, veritically. Next time I'm under the hood, I'm going to try and devise a way to mount it directly to the tower brace, which would be a VERY GOOD source to read road noise.
[ December 14, 2001: Message edited by: Iago ]
Old Dec 14, 2001 | 07:34 AM
Brendan's Avatar
heres the pic.
Old Dec 15, 2001 | 06:24 AM
ozwald300's Avatar
Hey guys I'm a little confused my went on perfectly I put the brace on then put the knock sensor on and tightened it down. wink.gif smile.gif
Old Dec 15, 2001 | 06:46 AM
ozwald- Then it sounds like you should be okay. As long as your inertia sensor is mounted similar to the way it was before.
