Steering wheel shaking
Old May 6, 2004 | 11:53 AM
canadianshark74's Avatar
Has anyone been able to fix this problem off the steering wheel shaking?
I replied to a post on HP about this.
http://www3.hyundaiperformance.com/forums/...?t=50382#416046
I just had my rotors and pads, ss brake lines, installed a few weeks ago. and my new rims and tires installed last weekend.
after driving around on the weekend I notice a clunk or something like that from the right front of the car. it happens when the car comes to a complete stop or hitting a bump.
Steering shakes a little with my 15's, shook a lot with my 17's, now i have brand new 16's and they shake too. But the shaking comes and goes. Driving over 100kms/h it will be fine for a while then it will start to shake for a bit. I think it might be my front left strut going bad.
New parts:
Wheel Bearings
Rims + Tires
Hub centric rings
Rotors + Pads
Belts are new
Ball joints are good.
Alternator seems ok.
Stut bars front and rear.
Old May 6, 2004 | 12:04 PM
have you gotten things aligned and balanced?
Old May 6, 2004 | 12:06 PM
that is what i am going to do next. I had it alinged last year after they installed the springs.
but what about the clunking? if i need new struts I may as well have them install them, then align everything.
Old May 6, 2004 | 01:12 PM
Sznurek's Avatar
my watch makes the most annoying vibrating sound when im on the expressway. i've had the same problem ever since i bought my car.
Old May 6, 2004 | 01:20 PM
TibOne's Avatar
i would say to get the car balanced because when i had to get a new tire put on, i was cheap and didnt get the car aligned and balanced, so when i got to around 90-100 kph the steering wheel would shake like a mother canucker, then i got the car balanced and it drove good as new... that could be your problem
Old May 6, 2004 | 01:45 PM
cjme2002's Avatar
mine started shaking when i got new rims (17's), we got it balanced and aligned, but it still shakes...usually from about 65 until 75mph. i'm used to it now though.
Old May 6, 2004 | 02:33 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
then they prolly did a half-ass job balancing the wheels.
being that mounting and balancing wheels is my job, what it sounds like is a poor balance.
Find out how they balanced it. if they have a Coats Computer Balancer, find it if they "static" balanced it. if they did...tell 'em to rebalance it on "Alloy 2" (it's a sticky weight on the outside portion of the rim (cannot be seen)). static balance isn't a true balance because they just stick a weight on the outside only and can result in a high speed vibration
and don't get "used to it." a poorly balanced tire can cause undesirable tire wear. it wears in blotches from the tire not hitting the road perfectly all around
Old May 6, 2004 | 02:55 PM
tibwrcsbj's Avatar
it will also shake if your tires are unevenly worn, OR IF A WHEEL BEARING IS GOING BAD. thats what my problem was, it still shakes a tiny bit, but not bad. The wheel bearings SHOULD be covered by warranty. have someone check that too.
Old May 11, 2004 | 10:17 AM
Jaws021's Avatar
replacing struts, wheels, tires,.... would throw the allignment out the window
Redo that..
also... check if they balanced the wheels... THATS VERY IMPORTANT.
Old May 11, 2004 | 10:43 AM
the wheels are balanced perfect.
I have a set of KYB's, coming in 2 weeks, when they get installed they are doing an alingment as well.
I will update this post after everything is done.
