Ss Brake Lines
Old May 24, 2006 | 02:23 PM
tdonnell's Avatar
Hello everyone,
I have recently installed rotorworks drilled/slotted rotors all around and had a problem with the rear brakes locking up first. I fixed that problem with the master cylinder and proportioning valve from my other tib. But now it is impossible to lock up the tires under heavy braking. So I know I can stop faster, but i can push the pedal to the floor without locking up the tires. I have bled the brakes completely and I KNOW there is no air in the lines so I figure the stock rubber lines are just expanding under heavy braking.
Anyway, I know the goodrich lines are the best of the best. But obviously I can't get them right now due to the lack of a GB.
So I was wondering if anyone had some recommendations for good quality lines for a 98 fx tib.
Thanks.
Old May 24, 2006 | 02:31 PM
find 10 people and ill run another....
shop.hp.com should have a set of different brand havent heard anythin about them though
Old May 24, 2006 | 02:33 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
how many miles did you run with new rotors and pads?
it's recommended to not brake hard for some time (till rotors be shiney like mirror)
maybe you glazed pads?
Old May 24, 2006 | 02:40 PM
tdonnell's Avatar
Well, during the break-in process, I did brake pretty hard, but I remember from school that you should increase your speed and decrease your stopping distance as the process continues. And always leave about 30 seconds in between each stop to allow for cooling. I don't think I glazed the pads. If I stop hard a few times in a row, it will definately stop better. I suppose I just need to heat up the semi-metallic pads to get maximum performance.
I would still like some ss brake lines though.
Should we change this thread into a "gauging interest in another goodrich gb" thread, or start a new one?
shopHP does have a set from 'techna fit'. I dunno about quality and they would cost about 120 shipped. The pics look ok and I can get them with pvc coating for corrosion and abrasion resistance.
http://shop.hyundaiperformance.com/shop/it...p?i=TEC_HY-1510
What do you think guys?
Old May 24, 2006 | 03:20 PM
I've got 2 sets of the Goodridge lines. Sell you a set for $125 shipped mang. Lifetime warranty.
Old May 24, 2006 | 03:32 PM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
Is that for front and rear Redz?
Old May 24, 2006 | 03:33 PM
ya he put up a forsale on them
check it out
and yes front and rear
Old May 24, 2006 | 04:57 PM
tdonnell's Avatar
Wow, didn't know that. Guess I didn't search hard enough, lol.
Anyway, PM sent.
