Someone Help Me Out With Webtech?
Old Nov 26, 2005 | 12:51 PM
The_Alpha_Male's Avatar
i'm changing my front pads, and i'm already late for work.
it just HAD to be done today though.
can anyone possibly find the page with the front caliper removal and pad replacement for me?
i'm having serious trouble finding this crap....
*edit*
nevermind... i'll figure it out without the info. it's just a caliper. heh
Old Nov 26, 2005 | 01:11 PM
'treezy's Avatar
FIRST:
Read first post insructions
SECOND:
Front Caliper removal
Old Nov 26, 2005 | 01:19 PM
i just found it... thanks though pat
MOD EDIT: quote removed
Old Nov 26, 2005 | 01:51 PM
you really dont even have to remove the calipers. just take out one of the caliper mount bolts and loosen another, then just swing it out, allowing it to pivot on the loosened bolt.
Old Nov 26, 2005 | 02:18 PM
QUOTE (tibby01 @ Nov 26 2005, 12:51 PM)
i tried that at first, but the bolts are just too tight. had to take it off. thanks tho mang
Old Nov 26, 2005 | 05:09 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Look who the pack dragged in. Good to see you around Alpha.
But yeah, sometimes the gunk and grime doesn't allow for the caliper to swing. Unless you service them quite a bit. There is just too much crap to let the caliper turn freely.
I'll assume you solved everything Alpha and your set to go?
Old Nov 30, 2005 | 02:24 AM
** MOD EDIT: quote removed
sure did. 8^)
everything's kosher!
