replacing rotors on 97 w/ 99 tib rotors
Old Oct 19, 2001 | 10:12 AM
ICE3X's Avatar
Default replacing rotors on 97 w/ 99 tib rotors
ok, i found a 99 tib at a junkyard that has the new rotors on the front, (non-captive)
what all should i get off that 99 tib to make the conversion easy to my 97 tib.
it's all still there, rotors are just rusting,
which i think i can get cleaned up.
Old Oct 19, 2001 | 02:54 PM
Tiburon_69er's Avatar
if it is not the FX model, you are fine! The 97 - 99 models are the same parts. The FX model had 4 wheel disc and ABS. that is a differnt brake setup. But same rotors. So I think you will be fine!
