Rear Brake Pads Replacement Problem
Old Apr 8, 2005 | 12:33 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
QUOTE (blacktibby @ Apr 8 2005, 05:44 AM)
Can't you use Anti-Sieze too? That's what i used today ...
One of my rods was totally rusted in so i SMASHED it with a hammer while it was in a vice. The i twisted it until it came out.
Problem solved..
I was afraid to hammering to much cause bracket is made of cast-iron and could be easily cracked.
Old Apr 8, 2005 | 02:31 PM
if anti seize will hold up against extreme heat, then yes. those brake get fvcking hot man.
Old Apr 8, 2005 | 03:04 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Seems to be common on tiburons that the guides seize. I had the same problem, they are supposed to "float" but mine were not doing so.
Glad you got everything fixed up Dmitry.
