Quick Question
you'll probably want another answer but im pretty sure when i did mine it had a LH side and a RH side because it goes under the console, through the floor and then goes in opposite directions to each rear wheel, depending if though brackets you can get from a screw in from both sides you might be able to flip it and get away with it but try calling your dealership, depending on the area i know some people got it for ALOT cheaper then when i got it from SFR
which is suprising cause there usually 3x more expensive then any other source
