Question for 2000 Lo and So Tibby
Old Aug 9, 2001 | 04:33 AM
Full, true coilovers are available from korea, but they run about $2000 a set.
If the Billstein setup you mention has everything you said...it probably going to be more $$$.
HKS makes some coilovers for tibbies, there are also various different Korean companies that make coilovers.
Contact Boogyman of Shark Racing if are serious about coilovers. He should be able to hook you up, but they are going to be expensive....
HDK AutoSport offers "Best" brand Coilovers for about $800, but they are not quality, and I would not vouch for how long they would last.
Old Aug 10, 2001 | 01:17 AM
Turboman....yeah..basically what Random said. (Thanx Random ) On another note, I know that Bilstein makes just regular shocks and struts for lowered vehicles. Contact them and see about getting a set for your car. Bilstein is top quality and will outlast your KYB's.
As far as installing the Eibach's....you can do that, but remember..the Eibachs are not that low of a drop. Only about 1.2" You can get away with the stock struts/shocks with the Eibach springs, but wouldn't recomend it. Any type you lower your car, you want to really try and have all lowering components. So if you get drop springs, then you want a good set of drop shocks to go along with the system. I'm not too sure on how low the Viden Springs lower your car. If they're around 2" or so, then that's why you'll have a les than perfect ride quality. The lower you go, the more harsh the ride is..unless you actually go with something like an air suspension.
Going by what you described on the PSS9's, they sound like a really good thing to get...but like Random said....chances are they're gonna be expensive. Any type of one specific dop component that is able to do everything that you listed, rest assured it's not going to be cheap. Good luck with it, and let us know if you have any other questions. wink.gif
L8TR............
