Problem with brakes???
Old Feb 28, 2003 | 03:09 PM
MyTibby's Avatar
Default Problem with brakes???
The other day, I was getting out of a parking lot, and as I was inching my way to the main road, I was going down a pretty steep hill and as I was braking, they started to really grind. I never noticed this before, and I dont know if it is just because of the steep hill or it could mean that my brake pads need to be replaced. But when I brake at any other time, they don't make a sound. I have about 33K miles on these brake pads.
Old Feb 28, 2003 | 04:44 PM
Russ's Avatar
I don't know if this has too much to do with it but is it colder than crap where you live? I noticed my brakes doing that sort of thing as well but then again I might need new rotors. That's a different story all together but it feels like there is a difference with the cold where I live.
Old Mar 3, 2003 | 01:46 PM
MyTibby's Avatar
It is very cold where I am at, and that could have something to do with it. My car does not function in the cold at all. Like when I close my door, sometimes my window is jammed and cracked open until I roll it down a little and back up. Also the locks just dont unlock most of the time.
Old Mar 4, 2003 | 01:43 PM
If the brakes and rotors were cold at the time, that noise is normal. Our metalic brake pads make hella noise when they are cold. After a couple of stops, they heat up and the noise goes away. If you go back to that same hill, with warm brakes, I'm sure you won't hear a noise. If you go back with cold brakes, I'm sure you can reproduce it.
