Problem With Brakes
Old May 30, 2006 | 01:31 PM
zoned019's Avatar
Vehicle: 97 Tib
I just changed my rear caliper because it was rusted and seized up. I turned the car on and the ebrake light comes on and I have no tension in my brake pedal. I pumped it about 5-10 times thinking it would build up, which it does, but after I let it sit for about 10 seconds it goes back to nothing again.
Was there something I forgot to do?
(To get the new caliper on I disconnected the fluid line, opened the bleeder, and tapped the piston down with a hammer.)
Old May 30, 2006 | 01:36 PM
tanc's Avatar
Vehicle: 1997 Tiburon
You blead the system? Connected everything? Have a leak anywhere?
Old May 30, 2006 | 01:37 PM
zoned019's Avatar
Vehicle: 97 Tib
When you say "bleed the system" does that mean ...
open bleeder
pump brakes
close bleeder
I did that .. but I think I may have had the brake fluid line disconnected, lol. I just remember seeing it disconnected right before I hooked everything back up again and I was like wtf..I was hoping that there might be something else I did wrong that would be easier to fix than taking everything apart again. Guess I'll go try to bleed it with the brake line connected now. LOL.
Old May 30, 2006 | 01:43 PM
tanc's Avatar
Um, yes.
LOL looks to me you are having some serious troubles recently. I'm not sure if your rushing things or what not but just take your time.
Also make sure there are no bubbles at all for each line. Follow webtech bleeding instructions.
Old May 30, 2006 | 02:12 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
fill some brake fluid in reservoir and bleed a contour (rear left+front right wheel or rear right + front left)
Old May 30, 2006 | 02:22 PM
simmah downa zoned. also, search. you definately have air in your lines and have to bleed them. the proper way.
Old May 30, 2006 | 03:02 PM
zoned019's Avatar
Vehicle: 97 Tib
tibby, this is the caliper i bought from you a long time ago. was it empty when you sent it?
Old May 30, 2006 | 03:08 PM
like i said to you online
brakes > sunny
Old May 30, 2006 | 03:22 PM
lmfao. why would i send you a caliper full of brake fluid that will just fall out everywhere? you never ship things full of fluid.
Old May 30, 2006 | 03:28 PM
zoned019's Avatar
Vehicle: 97 Tib
I dunno I can't seem to get all the air out I've been pumping, tightening bleeder, pumping, loosening bleeder, repeat. for about 15 mins now and can't seem to get much fluid going through, it just spits a little bit each time..
and i don't know, I've had things shipped to me in worse conditions before. LOL.
