Overtightening lug nuts
Old Jan 24, 2012 | 05:05 PM
blacktiburon's Avatar
Vehicle: 2006 Tiburon
Default Overtightening lug nuts
Other than it being impossible to remove them, unless you have a breaker bar or air tools...what other problems can happen if your lug nuts are tightened up too much from a mechanic?
Old Jan 24, 2012 | 05:17 PM
Your wheel studs can snap, your wheel could be damaged, clearances can be compromised depending on the design of the hub.
Old Jan 24, 2012 | 05:31 PM
Red Raspberry's Avatar
If they aren't tighten fairly evenly then you can warp the rotor.
Old Apr 18, 2012 | 09:25 PM
Tak82's Avatar
Vehicle: 1997 RD 4-door
almost all hyundais use 80 ft lbs of torque for each lugnut,
if they cross thread em or stretch them..make the service manager replace em.
i always put a note on my work invoices if i had tough time unbolting the lugs on customer cars
Old Apr 18, 2012 | 09:29 PM
wheel_of_steel's Avatar
Every knuckle dragging tyre fitter I've ever had to deal with rattles up my lug nuts to ungodly levels. I literally have to stand on my four foot breaker bar just to crack em.
