need help with tires
Old Aug 12, 2004 | 07:32 AM
mikemelanson's Avatar
Default Re: South Chapter Members edit
just wanted to know if 185/65R15 tires will fit on a 2000 tiburon fx
Old Aug 12, 2004 | 08:14 AM
Boricua's Avatar
Default Re: raffles
Why are you going with a taller and narrow tire for? The stock is 195-55-15. It will look like you have bicycle tires on it.
Old Aug 12, 2004 | 08:17 AM
Default Re: need help with tires
this is just for the winter
I had a good deal on winter tires of this size and i was wondering if they would fit on my stock rims?
Old Aug 12, 2004 | 08:26 AM
CyberShark's Avatar
Stay with the stock size. If you go taller, you'll throw off your speedo. You can do a search on this if you want, similiar subjects have been covered often.
Old Aug 12, 2004 | 08:34 AM
Default Re: Warning for Fake Veilside Body Kits
Old Aug 12, 2004 | 08:44 AM
CyberShark's Avatar
They will fit on your rims but you better check to see if it won't rub against your fender. Going form a 55 to 65 is a big difference in height. It will feel like you've added lower gears. I wouldn't do it but it's up to you.
Old Aug 12, 2004 | 08:49 AM
Ok thx guys I think I will skip on these ones
Old Aug 12, 2004 | 11:45 AM
rallyman's Avatar
Default Re: Seat Covers?
The 185's would be 4.4% different than the 195's and will throw off your speedometer and odometer readings by that amount. See the numbers below. It's not a huge difference but you should try to stay as close to the stock numbers as possible.
Specification Sidewall Radius Diameter Circumference Rev's Difference
195/55-381 107 mm 298 mm 596 mm 1871 mm 535 / km N/A
185/65-381 120 mm 311 mm 622 mm 1952 mm 512 / km 4.4%
I ran 175/65/14's for three winters on my Tib but they are a little closer to the stock size. Narrower is better when its comes to driving in snow.
