My New Rims, Neeed Help
Old Mar 8, 2006 | 11:28 AM
TibbyFx98's Avatar
Vehicle: 1998 Hyundai Tiburon Fx
so today i got my new rims in today but i totally forgot about these F&%&* captive rotars and they wont fit right.
--would these wheel spacers be a good temporaily fix till i do a non captive swap
Wheel Spacers
which one should i go with the 25mm or 15mm
Thanks in advance
Matt
Old Mar 8, 2006 | 11:30 AM
tanc's Avatar
Vehicle: 1997 Tiburon
Well, you do not need 15mm spacers. You can either bore out the back of your rims to make room for captive setup or you can go with 8mm spacers.
The heads of the bolts only come out 7mm. Also if you get wheel spacers, make sure to get hub centric wheel spacers.
Old Mar 8, 2006 | 11:32 AM
TibbyFx98's Avatar
if i have someone bore out the back will it hurt the strengh of the rims ?
Old Mar 8, 2006 | 11:33 AM
tanc's Avatar
It depends on the rims you have. In most cases no, unless its really thin. All you would need to bore out 4 holes 7 mm's
Old Mar 8, 2006 | 11:37 AM
TibbyFx98's Avatar
ok thanks, how about the one that is on the rear disk, it just have 1 screw i would prolly need to bore that part too, and sry about this i really dont know much about the wheels except how to change them
Old Mar 8, 2006 | 11:39 AM
tanc's Avatar
In the rear you have non captive setup so you should be fine. I'm not talking about the BIG hub bolt when I mean boring out your rims. It's the little ones I'm referring too.
Old Mar 8, 2006 | 11:42 AM
TibbyFx98's Avatar
i c what u are sayin, i would never attempt this myself i will have to take it to some wheel shop or something
Old Mar 8, 2006 | 11:47 AM
i dont see those spacers fitting with the captive bolts. those fuggers are a lot bigger than those little oddly drilled holes in the spacers.
Old Mar 8, 2006 | 11:57 AM
Sparticus's Avatar
Vehicle: 97 Tiburon
http://www.rdtiburon.com/index.php?showtopic=14232
Old Mar 9, 2006 | 08:53 PM
TibbyFx98's Avatar
Sparticus i would take u up on those if i had the funds, but i spent all my money on the rims so i am kinda broke with a set of rims sittin at the house collectin dust
but thanks 4 the offer
