Looking to buy a brake bleeder kit...any suggestions
Old Mar 26, 2012 | 12:01 PM
WRC_Accent's Avatar
Vehicle: 2000 Accent
Default Looking to buy a brake bleeder kit...any suggestions
I am tired of needing two people to bleed my brakes. Any suggestions on a kit?
Old Mar 28, 2012 | 10:49 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Google Phoenix bleeder.
Old Mar 28, 2012 | 11:05 PM
krazytib's Avatar
Motive Products Power Bleeder Kit works great.
Old Mar 28, 2012 | 11:35 PM
300D50's Avatar
Old fridge compressor and a 1 gallon drywall compound bucket, some tubing, and a few pinch valves also works well.
Old Apr 18, 2012 | 09:09 PM
Tak82's Avatar
Vehicle: 1997 RD 4-door
pump it with foot and wedge a small stick or jackhandle between the pedal and the front seat..thats how i do it when i'm working solo..
get a empty plastic bottle with a cap in the hole, some pvc hose and some old brake fluid,
Old Apr 19, 2012 | 07:03 AM
Red Raspberry's Avatar
All you need is a some 1/4" ID vinyl hose, a 1/4" x 1/2" bolt, a 2 small hose clamps for the hose and a plastic bottle with a cap.
Drill a hole in the cap so the hose can fit snuggly though it.
Put the bolt in the end of the hose and clamp it in.
Cut a 1/2" linear slice in the hose just above the bolt.
Put hose in bottle and screw on the cap.
Put hose on bleeder nipple and use clamp to hold it.
Open bleeder a quarter turn and start pumping.
As you push down on the pedal the fluid expands the slit in the hose and comes out.
As you let up on the pedal the hose collapses sealing the slit.
Old Apr 21, 2012 | 06:44 AM
larryinkc's Avatar
Vehicle: 2005/Hyundai/Tiburon
I put speed bleeders in mine. They have a one way check valve for one man bleeding. Worked great on my Tib.
http://www.speedbleeder.com/
