Increasing downforce on the front
And 400whp will break loose the tires at 60mph.
Vehicle: 2000 Tiburon
you would need to re-engineer the whole car for this idea...
you would need to redesign the whole front bumper, and underbody of the car. all of that open space under the engine creates alot of turbulence, even at a mere 40 mph. all the turbulent air pushes up on the car, until the air hitting the top of the hood and windsheild can overcome this and push down on the car creating downforce...
you would have to create a smooth surface from the lip of the bumper, to behind the wheels, covering up all those "holes" and air pockets around the engine and transmission.
also in the rear, from the front of the rear tires, all the way back to the lip of the rear bumper.
ive wanted to try something like this for a while, ever since i learned how to fiberglass...
take a thin bedsheet, tape it to the lip of the front bumper pull it back behind the wheels to the floor pans, tape it to the floor, and fiberglass resin the whole thing. just to create a smooth surface so air doesnt get trapped under there.
the caveat to all of this would be maintenance issues... how are you going to get to your oil filter, and oil pan drain. also heat, passing air would not be able to cool the engine as well, where would the air coming into the grill to cool the radiator go ?
so like i said initially, you would have to re-engineer the whole car, perhaps in a race application sure, but for a daily driver... not worth the hassle.
just do what the others said, stiff springs, stiff shocks, decrease front tire air pressure, increase rear tire pressure and ride height, which moves weight foward !
Vehicle: 14 EGT 2.0
Want to make it easy? Make a skirt, splitter, an anything that keeps as much air as possible out from under the car.. cut a big freaking hole in the floor of the car.. install ducting and a fan. Done...
OR maybe if the problem is during acceleration, practice accelerating in the limits of your tires, including feathering the clutch?
Theman didnt specify anything about drag racing, i think we are all assuming hes drag racing... maybe hes talking about high speed cornering. ?
The best way to avoid wheel hop is better suspension, and better technique. Feather the clutch so you're just barely NOT spinning, but instead right on that edge.
I do like the idea of a big fan in the front. Similar to those little RC cars that can drive on a wall!
