I need hubcentric help.....
Old Jan 30, 2003 | 02:30 AM
Austin's Avatar
Default I need hubcentric help.....
I just ordered rims from Wheel Max....and they did not come w/ hubcentric adapters. Where can I get them from? I know alot of you guys have rims, where can i get those bastards from? thanx
Austin
Old Jan 30, 2003 | 02:40 AM
stickshift's Avatar
Vehicle: 2000 Tiburon
Don't wheel places usually supply them?
If not, I think just about any shop that sells wheels can get them for you, if they know what size you need.
Old Jan 30, 2003 | 04:58 AM
Viper966's Avatar
hubcentric rings need 2 be the size of the diamerter of the hub space in the rim on the outside, and the diameter of ur hub on the inside....
call up wheelmax and bitch..... they should give them 2 ya
Old Jan 30, 2003 | 05:28 AM
Austin's Avatar
I did, they said they dont know what they are and they dont think my 2002 GLS needs them. Hopefully they will come w/ the rims. How will I know if they do?
Austin
Old Jan 30, 2003 | 05:56 AM
Hootie's Avatar
Call Discount Tire Direct www.discounttiredirect.com or Tirerack www.tirerack.com and ask what size you need.
Old Jan 30, 2003 | 06:01 AM
Austin's Avatar
I called tire rack, they only deal w/ their rims. Also Dicount tire direct doesnt have a number, just email address. Anyone w/ a 2001-03 GLS can help me out here =)
Old Jan 30, 2003 | 06:29 AM
stickshift's Avatar
The hub is 67.1mm in diameter.
The centrebore of the wheels you bought is probably bigger... most aftermarket wheels are made with the same size centrebore (one that is bigger than any car), and hubcentric rings of various sizes are available to allow aftermarket wheels to be fitted to just about any car on the road.
If wheelmax can't tell you if you need them or not, then do they know what they're talking about?
If the wheels arrive without the rings, go to (insert name of reputable wheel/speed shop here) and ask for 67.1mm/2.64 inch hubcentric rings or the closest thing to that number (and by close I mean like .1 mm or .01 inch or something like that. They have to be an exact fit.
I know Hyundai is one of few car companies to use a 67.1 mm centrebore. Most other cars use a smaller bore, so it's possible the wheels will fit right without them if 67.1mm happens to be that magic default centrebore size that aftermarket wheels are machined with.
Old Jan 30, 2003 | 07:01 AM
phorq's Avatar
phorq, hardend bitter by Wheelmax, shrugs and mumbles, "I tried to warn you they are fuggin' morons..."
Old Jan 30, 2003 | 08:09 AM
www.tires.com
Tell them what brand/size tires you bought, and what make/model car you have.
They will sell you a set of adapters for $10.
Old Jan 31, 2003 | 02:50 AM
Austin's Avatar
Thanx guys....I went to a rim shop nearby and they had them. paid 20 bux for them. I'd rather pay 20 bux now and be able to put the rims on when I get them rather than bay 8 bux(which is what tires.com quoted me) and get the rims on monday and not be able to put em on because i dont have the hub rings. But you guys have an AWESOME help. I'll post pics on here when I get the rims put on. Thanx again
Austin
