How To Roll A Rubbing Fender
Old Jul 6, 2009 | 07:21 PM
mannyr's Avatar
Just passing along some good info
If your front fenders are rubbing and you need to roll them
you can rent the tool for $50 from this people
http://www.rollyourfender.com/index.html
here is also another diy from another site
http://www.srtforums.com/forums/f75/how-ro...rs-15-a-395884/
another good funny how to DIY
http://www.youtube.com/watch?v=Wxmw-4A0DEQ
Old Jul 6, 2009 | 08:25 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Wider tires do not mean better traction, that's a misconception.
Anyhow, I rolled my fenders with that tool, could of done with a rubber mallet and have the same result. Mind you, I didn't heat the fender and the paint cracked but I don't care because car is getting repainted anyhow if you've seen my bodywork thread.
Old Jul 6, 2009 | 08:51 PM
mannyr's Avatar
the only reason why i mention this is because I recently bought a new set of front tires 205 17 40. These are the same size i had before but different brand and where the tire bends into the sidewall is a little bit beefier than my other tires. So for some reason whenever I make a sharp right turn going up a little ramp the wheel was rubbing on the fender and getting cut up. I have a rubber mallet I'm just going to take off the tire and fold it in. I have H&R springs by the way. I think they are 1.7
Old Jul 6, 2009 | 09:37 PM
UrS0NvS's Avatar
it's the rebound causing you to rub when you go up that little ramp man. take the corner to the ramp slower and you wont have this problem. or, take it at more of a angle. I have a really crappy entrance to my apt. complex but after a few tries i could get in and out out there was a vader style front bumper riding 2.5" off the ground and being lowered with the same size tires as yours.
sometimes, its just a matter of looking at your driving habits to save wear and tear on your car.
Old Jul 6, 2009 | 09:53 PM
mannyr's Avatar
I agree with you on that. But it definitely needs to be rolled because the lip is sticking out. So I need to make sure i tucked in tight against the inside.
Old Jul 6, 2009 | 10:01 PM
have my lip for both of my fenders are out cuz of something awhile ago, that i cant remember
but i running 205/40/17 with kyb/eibach setup and dont have rubbing issues at all...
only problem i have is this one shopping center parking lot with these huge speed bumps, but i crap my rear section of exhaust all the time, no matter how slow i go
its driving habits, i will fix mine later when car gets repainted
Old Jul 6, 2009 | 10:24 PM
UrS0NvS's Avatar
yeah, my driving habits will change alot also, down to near nothing,lol.
I bet i got a good four months of no driving after i get the tib out of the body shop with all the other stuff i wanna do to the tib.
Old Jul 6, 2009 | 11:06 PM
i believe you have a true bulid...like the ones seen on TV or in magazines...lol
Old Jul 6, 2009 | 11:21 PM
Albuquerquefx's Avatar
You should try with 225/45R17's and lowered... Maybe it's time to re-evaluate the offset on your wheels?
Old Jul 7, 2009 | 10:02 AM
mannyr's Avatar
red 225/45 arent those bigger why would i want bigger tires. And is mainly the right side that is rubbing. Im just going to roll them and problem solved
