Going for the BBK
Old Apr 2, 2010 | 12:09 AM
Fintile's Avatar
Default Going for the BBK
Ok well the time has come my calipers have finaly gone bad. I have a problem with my stock Accent pistons as they are not fully closing right. I have very poor braking even with brand new pads. The pads wear very unevenly and Im told its due to the piston in the calipers not evenly applying preasure. So here it goes...went on ebay looked up 99-01 Elantra/Tiburon parts:
2 Front Calipers
2 front rotors
2 front wheel hubs
2 sets of front brake pads
Now not sure if I have everything needed but I want to make sure before I buy all this that the hubs will fit my 04 Accent spindles.
Also is there anything I am missing aside from SSB brake lines (thats a given)?
Old Apr 2, 2010 | 11:39 AM
I have never gotten a solid answer about whether XD calipers will bolt up to the Accent spindle. IF they do, your list is all that you should need.
Old Apr 2, 2010 | 09:14 PM
Fintile's Avatar
hat do you mean calipers bolting to the spindles? Isn't that why i would be swapping the hub? or are you meaning that the hub may not fit?
Old Apr 3, 2010 | 12:17 PM
The hub is just the thing with the wheel studs and a bearing on the back. It's pressed into the spindle.
If you're getting the entire spindle you'll be fine.
Old Apr 4, 2010 | 06:41 PM
Fintile's Avatar
uggh...now i need the spindle
Old Apr 11, 2010 | 08:50 PM
Fintile's Avatar
ok, so are we for sure that the 99-01 Tiburon / Elantra spindle will fit the Accent?
Old Apr 12, 2010 | 12:15 AM
if your gonna get the calipers and rotors anyways
do my xg 2 piston bbk
xg calipers, spectra 5 rotors (2005)
hawk pads (my personal fav)
they bolt on to the rd/j2 spindle
Old Apr 12, 2010 | 02:03 AM
Fintile's Avatar
ok Im having trouble getting my cursor to allow me to type AFTER the quote. Anyway I didn't know that. I vegly remember that post at HP. well shoot if they bolt up no problem to the RD spindle I'll do it but does that RD spindle mafit the Accent LC2? SO I woud need these rotors: http://cgi.ebay.com/ebaymotors/KIA-SPECTRA...tZMotorsQ5fCarQ
5fTruckQ5fPartsQ5fAccessories?
QUOTE (faithofadragon @ Apr 11 2010, 11:15 PM)
Old Apr 12, 2010 | 02:06 AM
Fintile's Avatar
and these calipers? http://cgi.ebay.com/ebaymotors/02-03-HYUND...sQ5fAccessories
Old Apr 12, 2010 | 04:19 AM
I think the RD/J2 spindle bolts in, but I KNOW the XD Elantra spindle bolts in.
