G4 Racing Coil-overs... Know Them?
Old Oct 20, 2006 | 08:30 AM
gsasha1's Avatar
Vehicle: tiburon 1998
Hi,
Did you hear of these coilovers?
I searched a little, and they seem to be the as the ones sold by D2, and maybe KSPORT.... but under different name...
they are sold on http://www.performancestylingcentre.com.au/ and many Australian forums...
Here are their specs:
Benefits - Allows fine tuning of suspension ride height to achieve better handling
- Ideal for show cars, allowing for ride height to be greatly reduced for looks when required then raised back to a more 'normal' low ride for every day use
- G4 shock absorbers use a separate gas and oil (30% Nitrogen 70% Oil) monotube design that helps reduce oil leaking defects.
- The dampers can be disassembled, and rebuilt to meet all requirements. The shock absorber also includes high-performance front pillow ball top mount (Macpherson Type) to complete this unique products.
- Manufactured using lightweight 6061 aluminum alloy material with T6 for increased hardness, and formed by forging and anodized to avoid losing color.
- All models can be lowered to 120mm less than the original height when shock absorber is fitted.
- Linear rate spring with chrome silicon metal alloy springs, available from 3.5-22 kg/mm.
- Top turning adjuster to adjust damper and rebound up to 36 ways. All shock absorbers are adjustable for both compression and rebound.
- Teflon thread coated to prevent rust and corrosion.
- G4 shock absorbers are qualified by "World ARTC" for million circles with no liquid leakage, qualified as race proven equipments.
- 12 month replacement warranty
RD & RD2 Coupe
(7.5 kg/mm front, 5.1 kg/mm rear) G4R-COI-RD1
Priced the same as the ksports too...
The reason i'm asking is since I'm visiting australia in April, I will be able to avoid the shipping to Israel...
Thanks, Sasha.
Old Oct 20, 2006 | 06:57 PM
Osv4's Avatar
hehe..but how your going to carry them back to Israel? =S put it into ur bags? They are pretty heavy wink1.gif
Old Oct 21, 2006 | 12:11 AM
gsasha1's Avatar
Yeah! bringing an extra trolly.... How heavy?
Old Oct 21, 2006 | 12:46 AM
they would be like 40lbs. tops
Old Oct 21, 2006 | 12:50 AM
gsasha1's Avatar
worth the 300$ spared for shipping?! hell yeah. ^^
Old Oct 21, 2006 | 04:32 PM
Vladimer's Avatar
Vehicle: 01 Tiburon SE
gona sound stupid, but what are those little black wrenches, got em with my coilovers and no clue what they do,
i dont mean the crecent ones which you tighten everything with, i mean those straight ones
