Damage From The Accident..
Old Mar 6, 2007 | 08:51 PM
zoned019's Avatar
Vehicle: 97 Tib
120 for control arm, spindle/knuckle, axle shaft from a junkyard.
are there aftermarket sway bars?
what is a hub? lol.
Old Mar 6, 2007 | 08:56 PM
^^ you can get a bigger badder one from a GK.
I saw the swap done on an older elantra at a DFWHyundais meeting. It should work for our tibs. Our sway bars are pretty good to start with though.
Old Mar 7, 2007 | 05:10 AM
xxxmonoxidechild's Avatar
doesnt work. GK bars only fit on the XD elantra's, which are very similar to them, and not us RD's. people have tried fitting up the GK sway's, and there just not comparable at all. hell, ask faith even.
Old Mar 8, 2007 | 07:21 PM
NY Turbulance's Avatar
Hub and spindle are two different parts, hub sits on spindle w/bearing, with studs sticking out for your wheel lugnuts. Not sure if the hub question was a joke or not, but just in case.
Old Mar 8, 2007 | 07:34 PM
zoned019's Avatar
Vehicle: 97 Tib
oh i know what a hub is, i made that sound retarde, what i wasnt clear on is if it was a separate part. i thought it would come with the spindle. but guess it doesn't! thx
Old Mar 10, 2007 | 07:34 AM
but you are right that the spindle and knuckle are the same thing
Old Mar 10, 2007 | 08:43 AM
you can buy eibach sway bars if u want aftermarket.
and for the axels i would buy those new, dont trust junkyard for a part that important. they cost like 75-80 bucks new so make sure you do the job correctly with new parts
Old Mar 10, 2007 | 06:37 PM
zoned019's Avatar
Vehicle: 97 Tib
the eibach sway bars REPLACE front and rear oem ones? or they attach to them to make them stronger?
