Car Problem! Steering Wheel Shakes And Pulls Hard
get a real shop to balance your tires!! a make sure they have a roadforce machine.
with my tib the slightest unbalance and i would feel it....my elantra not so much....but roadforcing the assembly helps tremendously
I've had my tires balanced once (with the purchase of 4 new tires), already ... this was happening with the tires I had on when I bought the car too. However, I never did specifically ask that the balancing of the new tires be done using a "roadforce machine". Thanks for the tip, only1tib, I'll give that a try in Jan after putting in the kyb struts.
damn!! I was betting that that was the cause of the problem! Let's see if the wheel balance using a roadforce machine, helps.
QUOTE (Rayne9707 @ Dec 10 2008, 01:51 AM)
Not to be a downer fury but i think were screwed i just put on 4 kyb gr2 gas shocks and 4 new mounts that wont change it
Have you checked to make sure both axles are balanced. I had a violent steering wheel vibration, and one day i jacked both front tires off the ground and removed them. I put the car in first gear and watched them rotate and the passenger side axle was bent. my .02 cents
A new one is about 50 dollars after core charge. And i changed it myself in a gravel driveway on some jack stands. It took less than 2 hours, but i wouldn't go replacing anymore parts until you figure out what the vibration is. A bent axle can cause steering vibration, but that is just a suggestion to look into. Do a visual rotating inspection first, if its bent you will be able to see it.
