Buying New Tires
QUOTE (ScoupeLS @ Jul 23 2007, 05:32 AM)
I'm running 35 profile on 19" rims
Well that's your problem right there, they're pretty much rubberbands I'd imagine.
If I ever get around to it before winter starts Im gonna give the kumhos a try. Probably in a bigger tire, like 215/45/16 or maybe 40 since Im lowered now.
I have 0 traction with these tires on the snow, I'm running 35 profile on 19" rims so I dont know if that afects.
2 years ago they started charging people in Ontario for driving in the snow with low profile tires. I'm running 35 series on 18s, and its a bumpy ride, but I don't mind. But I avoid driving in the rain just in case. I had to pull the car out onto the driveway once in the snow, and it took almost 45 minutes to get it back in the garage.
But from the sounds of the first post, its basically a stock rim, so it all depends on the size of the tire.
well after narrowing it all down i ended up with the g-force sports and the exclaim UHP's
the yoko's looked real good but there tread wear was pretty bad
the g-force tyres weight 20 pounds each but the exclaim's are only 17lbs, 3lbs per wheel is quite abit isint it?
and the kumho sort of fall in the middle of the 2
I've got the Kumho Ecsta SPTs on stock rims and although they are fairly grippy, I find them to be really noisy. They are however, a directional tire so that's to be expected, I'm sure. And treadlife has been disappointing as I've only got around 27k on them and they are down to the wear bars already.
QUOTE (Vladimer @ Jul 23 2007, 09:01 PM)
You live in calgary man...buy 2 winer tires now and some all seasons in April
