Brake Fluid vs. Clutch Fluid
Old Apr 7, 2011 | 02:19 PM
Red Tib's Avatar
Vehicle: 99 Red Tib
Default Brake Fluid vs. Clutch Fluid
Hi I read that brake fluid and clutch fluid are the same thing. Does that mean replacing the brake fluid is the same as replacing clutch fluid.
Or are the brake fluid and clutch fluid two different things that need to be changed, but use the same fluid?
Also how often should I change the clutch fluid. There is no mention in my Chilton manual.
Thanks for the help.
Old Apr 7, 2011 | 04:09 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
Same stuff, bleeding is about the same, and for how often.. open the cap. I know on my XD it would start to turn grey/look like crap. Good time to change it once it does that.
Old Apr 7, 2011 | 04:20 PM
same fluid 2 different places to change em from
Old Apr 7, 2011 | 04:22 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
^ forgot to mention that.
Old Apr 7, 2011 | 04:43 PM
BAD DOUG
Old Apr 7, 2011 | 09:28 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
I did him a favor if his brake fluid went gray as well... so yeah.
