accent struts
Old Mar 31, 2011 | 08:51 AM
decos accent's Avatar
Vehicle: 2005 hyundai accent
Default accent struts
Like it says. Iv been looking around and can't seem to find anything. What's out there what else will work. I know the tib, or lantra struts are close but are they close enough. Any help on this subject would be nice, I have my stock struts with tib coil over sleeves and springs now, I got a nice low ride hight, the ride could be better, maybe some helper springs, but my struts are about gone. Thanks
Old Mar 31, 2011 | 04:13 PM
Good: KYB GR-2 struts. Handle some drop okay. A lot better than stock but not really a true performance strut.
Better: Koni yellow inserts. Cut the top of your strut off, install inside the body, enjoy. Expensive but good and adjustable.
Old Mar 31, 2011 | 09:49 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
Do the Koni yellows come for the X3?
Old Mar 31, 2011 | 10:34 PM
IIRC yes for the 97-up, but would have to use 97-up strut housings on an earlier Accent. Either way measure the strut housings on an X3 before buying. Koni lists the correct diameter.
Old Mar 31, 2011 | 10:53 PM
Juanra's Avatar
I use front X3 and rear RD struts because of how I did the rear disk swap.
I went to the site and they only had for the RD, is that one compatible with the X3?
Old Apr 7, 2011 | 05:35 PM
Ok so I checked it out a bit, not really getting how to go about ordering the koni inserts. I would like to go with them but can't afford to order wrong. Does anyone have a part number? I think with my ground countral sleeves, and if I add some helper springs it should make for a nice ride.
Old Apr 7, 2011 | 10:10 PM
Call/email them directly for advice making measurements for their product.
