Bilstein Struts Any Good?
Old Jul 28, 2006 | 11:18 PM
^aww, i remember you posting the dog!! soo cute. i love dogs. haha a pair of four, i meant the whole set. HAHA. it would be bizarre if they sold struts one by one. hehehe laugh.gif
i really want to order them asap.
Old Jul 28, 2006 | 11:44 PM
Rd1tib's Avatar
i heard that with konis, when it blows you can fix it by changing the valve or chamber really easy. so like the konis are i guess cheaper to repair, when compared to the agx. AGX is adjustable from 1-4 in the front and 1-8 in the rear. u can tell the diff from adjusting them.
the inserts-
- you have to cut up ur stock shocks
- remove the stuff thats inside the strut
- drill a hole on the bottom of the strut
- insert strut insert so that the stud on the bottom goes through the hole-
- tighten the nut to the bottom and yea..
there is a diy i found on google when i was in the market for struts.
Old Jul 29, 2006 | 08:33 PM
damn i did not know that! thanks rd1! hmm... i'm up for that if it's really worth the strut. i fount eibach struts on ebay for our cars!!!! maybe that's the better pick although not cheap, i think if eibach designed it as an entire system that would probably be the best. i might just go with the eibach struts now i mean it's really a shame they don't sell them anymore. i will write a big review on it once it's all done.
Old Jul 29, 2006 | 08:42 PM
lilo shark's Avatar
when we put my cousins bilstein's on his m3 they were stiff as hell. rode real good. handling was improved significantly.
Old Aug 1, 2006 | 03:51 PM
well i ended up ordering the eibach springs and dampers afterall. i didn't want to mix and match unwillingly ending up with a result that doesn't fit my use. the reason i did so is because i've read a bunch of reviews that bilsteins are kind of on the stiff side.
they do look of really good quality. the reviews were for BMW's and Volkswagens. They must be really good however i need something that can absorb the shock more than it can repel it.
t01 you said they do this in autoxing? so it is possible to just swap out the struts and just keep the stock springs? i still don't understand how the ride quality would be. but i know from driving my dad's elantra all the time that his B+G springs, while being a bit bouncy, make a really cool ride.
Old Aug 2, 2006 | 09:09 PM
sorry about the bump i didn't want to make a new thread on a noob question but when you get the eibach pro kit on you need to do alignment right? eibach sells pro kit alignment sets for +1.75 adjustment or can i have it adjusted regardless?
Old Aug 11, 2006 | 11:28 PM
bumppedy triple post. you guys have any idea how long a backorder on struts and dampers takes from ebay?
(price is a little overboard, but i'd rather it be ebay for a product eibach doesn't distribute anymore)
Old Aug 11, 2006 | 11:36 PM
Rd1tib's Avatar
yeah when ever you do ur suspension stuff you shoudl do your alignment so that your tires would wear out evenly.
the alignment kit they sell i think is the camber kit. you could be fine without it if your drop isnt too drastic. When i dropped my ride 2.5+ (i think), my camber was pretty screwed up with the bottom of the wheel sticking out more than the top and toe was messed up as well. So i got the obx camber kit to fix it.
Stock have adjustable toe and camber but then they can be adjusted only so far.
not too sure about the back order thing though.. good luck
Old Aug 24, 2006 | 03:24 AM
hesus rd1! 2.5 inches. don't you live in san francisco?! what the **** no bullitt driving for you! cool.gif
today i thought i might give a little update of the goodies comin' in:
by the way, shox.com has awesome customer service. the guy was really sincere. and they have the eibach complete kit if you want to order the dampers, tirerack also has them but they have to order from eibach themselves. from shox it's going to be mid-october when i get the antiroll kit which is good there's lots of nasty construction goin' on in d.c. area.
Old Aug 27, 2006 | 06:15 PM
t28turbulence's Avatar
QUOTE (faithofadragon @ Jul 28 2006, 01:03 PM)
the blisteins are a insert like the konis
which mean you gotta cut open the stock strut to install them
you gotta be kidding me, your dont seriously cut you springs out of your suspension do you? You do know thats what a coli spring compressor is for right??
