a BIG set of 18's...
Old Nov 23, 2002 | 09:33 AM
justin's Avatar
Default a BIG set of 18's...
for anyone that has 18's on ur tiburon, is ur car lowered? do u have a kit? and how often do they rub? im thinking of an upgrade...
Old Nov 23, 2002 | 11:57 AM
G SHARK's Avatar
I have 18's and I have the Zefiro kit for my 2k tib, and my car is lowered about 2inches I have no problem with rubbing, just so that you know I also have a camber kit, so that also helps.
Old Nov 28, 2002 | 03:29 AM
justin's Avatar
anyone else?
Old Nov 28, 2002 | 03:48 AM
batman's Avatar
Vehicle: 01 Tiburon
yea i also wanted to know this and also how did u reset ur speedo for the size difference and what is the diameter across including the tire and what size tire u running on them
Old Nov 30, 2002 | 02:15 AM
phorq's Avatar
from what i understand 205/35/18 will keep your wheel diameter the same as stock, and you won't alter your speedometer/odometer... though your ride is going to be rougher than 16's and 17's.
you're gonna have something like 1 to 1.5 inches between your wheel and the road... just be careful not to hit too many large pebbles on the street along your sidewall that could damage the lip. and if you can get tires with a lip-protection-ridge i'd do it. my Falkens have that and it's great.
