Adjusting camber
Might need to straighten your chassis, or some bent part of your control arm/knuckle/etc... If you want more than 1 degree camber corrected, you can get Ingalls at mmrusa.com
I had a severe camber problem when my car was lowered, the alignment shop I went to didn't install a camber kit in my car though, they welded the points to correct it.
$60 bucks because of my extreme camber, normally they would charge $30 for a regular one, but because of the welds...
Name of the place is Clarence Brown Alignment Services. They take appointments only. Lemme know if you want their address/phone #.
dude, jaws, i've heard of agressive driving, but wtf with your sig. apparently, you drive your tib a little too hard. basically, WAY BEYOND AGGRESIVE. i mean, you don't have a link, so i don't know what you've done to it, like NAWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW WWWWWWWWWWWZZZZZZZZZZZZ or turbo, but i'm assuming whatever you've done, is just a bit too far without more planning to have all of those problems. then, since you hit a tree wink
, learn about weight transfer before you take corners too hard. ok, i just fell off of my high horse, so i don't have too much more to say. i know jaws has done a lot, but dood, you've also fukd up a lot, given your sig.
[ November 08, 2002, 11:27 PM: Message edited by: turbulence ]
, learn about weight transfer before you take corners too hard. ok, i just fell off of my high horse, so i don't have too much more to say. i know jaws has done a lot, but dood, you've also fukd up a lot, given your sig.[ November 08, 2002, 11:27 PM: Message edited by: turbulence ]
when avoiding a tourist...i ran over a huge curb and my control arm was jacked!! my camber was off and my wheel was pushed back like an inch!i still think its messing my up because every time i have an anlignment job done its still freaking not right...i probably bent my swaybar aswell....but looking into those they just might also be your prob! just my .02
Try Moog Chassis Parts. Cost should be around 13.00 per kit (side).
Tiburon 97-01
Front camber kit
-1 1/4 to +1 1/4
part # k9757
one kit per side
Rear camber kit
-1 1/4 to +1 1/4
part # k9757
one kit per side
Tiburon 97-01
Front camber kit
-1 1/4 to +1 1/4
part # k9757
one kit per side
Rear camber kit
-1 1/4 to +1 1/4
part # k9757
one kit per side
funny thing is... im not even done yet...
Leftside.. im going to be getting some springs soon.. so im going to get the whole thing alligned once they settle in
Ill let you know when...
thanx guys
thanx guys
