Adjusting camber
Old Nov 4, 2002 | 06:52 AM
JAWS 021's Avatar
Default Adjusting camber
Alright guys how do you do this?
I was told that eibach sells something so you can do this... but what is it?
My camber is all jacked up on the passenger side where a tree once hit me (thats my story and im sticking to it)
I was told that its not adjustable on these cars... so what super duper powerfull suspension mods do i have to get to fix this?
Old Nov 4, 2002 | 03:31 PM
leftside_ryder's Avatar
Eibach's camber kit is basically replaces strut to spindle mounting bolts that extends your wheels to correct up to 1 degree. Ingalls Engineering makes one that corrects up to 2 degrees, and I think it's the same price as Eibach's. Part # 3541PR .
Old Nov 5, 2002 | 12:28 AM
JAWS 021's Avatar
DOH!
i was hoping it was just some special bolts or something....
Dam i guess i have no choice but to buy those stupid struts
Old Nov 5, 2002 | 01:44 AM
Jmontigny's Avatar
Vehicle: 02 Elantra
What part is bent that your camber is messed up?
Old Nov 5, 2002 | 10:54 PM
Zman's Avatar
You're right Jaws021, the kit is basically a replacement for the strut BOLTS, as leftside_ryder said. I think it's around 35 bucks. But I think if your camber is different from one side to another, maybe the repair on you car wasn't good enough. Maybe you shoud check first if the structure of your car (sometimes called the "chasis") is well aligned.
Old Nov 6, 2002 | 03:43 AM
JAWS 021's Avatar
I took the car to get aligned and the passenger side was in the red zone (in that computer program)
I think the camber was like -1.5
The repair on my car was not bad enough to even mess up the fender
It just really jacked up my hood... CAUSE A TREE HIT ME!!! THATS MY STORY!!!
lol
Kool does anyone know where i can get those bolts... i might as well put in an order for those dam springs as well...
Old Nov 7, 2002 | 01:33 AM
Zman's Avatar
You can order them from The Tirerack.
I don't think there is a "part" wrong with your car, what I meant is when the tree hit you wink , maybe the impact twisted a little the structure of your car (it could have been a big tree you know ). That would mean even with new parts you wouldn't be able to get the geometry 100% OK because the problem is where the parts are mounted more than in the parts themselves.
That's something that can be corrected at a "traction platform", they kind of strech the body of your car to reach the OEM meassures. Though, I supose that is expensive.
Old Nov 7, 2002 | 04:21 AM
Jmontigny's Avatar
Vehicle: 02 Elantra
It sounds like the upper apron section where the three strut bolts are may be pushed in toward the motor. I would seriously look into that being the problem.
Old Nov 7, 2002 | 05:27 AM
JAWS 021's Avatar
oh wait... i did have a strut bar...
Those 3 bolts were removed at one point
DOH!
thanx guys... ill go bitch slap myself a couple of times
thanx zman and montigny (BTW thats a cool logo)
