2 Major Problems..someone Help
Old May 9, 2005 | 05:07 PM
  #21
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Well that clip may have something to do with it actually. Remember I said above that I swapped out my rear pards and rotors? I'll bet that was the cause. The shim over time prolly set it's self in a groove or was worn down enough not to cause noise due to the fact that the wheel mostly turns forward. Maybe the shimm is just catching the rotor when going backwards cause it moves differently.
See where I'm heading with this?? Where did you get your pads from?
Old May 9, 2005 | 05:30 PM
  #22
zoned019's Avatar
Vehicle: 97 Tib
why did it go away suddenly when i removed, then replaced the pads and made sure all those bolts were tight etc etc ... then come back a few days later?
i know it has SOMETHING to do with the brakes because it only happens when i slightly apply the brakes in reverse, if i accelerate in reverse it doesn't happen.
Old May 9, 2005 | 06:45 PM
  #23
Did you try removing the clip all together? When I went from stock to EBC a couple of years ago, I removed the "anti-vibration" clips altogether.. and have not had a single problem with either vibration or a braking. I would try removing them and see what happens. They might not be fitting your new pads exactly right, which would make MORE vibratiuon.
Old May 9, 2005 | 08:13 PM
  #24
zoned019's Avatar
Vehicle: 97 Tib
but only on one wheel? and the sound im almost positive is metal-metal...its a GRIND its so loud too, everyone who gets in the car like freaks out when they hear it beacuse it sounds like my wheel is falling off (like a bearing pretty much, but im pretty sure it's not that.)
could someone pull up some pics for me? what are the vibration clips? i've honestly never done anything more than brake pads, i don't know anything about wheels
i just remembered this, but the weird thing is when my pads were really low it was THAT wheel that was squeaky ALL the time, it was always squeaking and creaking (even moving forward), and was quite annoying.
Old May 9, 2005 | 09:14 PM
  #25
it almost sounds like you have a warped rotor..
Old May 9, 2005 | 11:19 PM
  #26
zoned019's Avatar
Vehicle: 97 Tib
Old May 11, 2005 | 07:50 AM
  #27
zoned019's Avatar
Vehicle: 97 Tib
....anyone?
Old May 11, 2005 | 10:32 PM
  #28
zoned019's Avatar
Vehicle: 97 Tib
i noticed (for some reason i tried this, idk why i decided to but ..) when i power brake while reversing, it doesn't make the noise..
also if i reverse and use the handbrake instead it doesn't make the noise
Old May 12, 2005 | 02:24 AM
  #29
Dmitry's Avatar
Vehicle: Elantra HD / 2007
sounds like problem with rotor/caliper/pads
Old May 12, 2005 | 09:37 PM
  #30
zoned019's Avatar
Vehicle: 97 Tib
yes but WHAT?
god i want to fix this problem soo bad, i don't know WTF to do though
