denis your the one that offered this right? I couldn't find it on the site the way I wanted it. I saw the little bits of pipe, I wanted to get one fabed up in aluminum 2.5 in. pipe, about the same size as the stock maf, I'm just going to replace it inline.
thanks! |
I might be down for one also, dammit Denis you need to put up a list of all the cool stuff you make haha
Ya he has them. Or used to I think.
What you will end up doing is undoing the torx bits on your stock MAF and putting it ito a flange in the hard pipe. Really nice idea. |
you guys need to check out the list of parts they make for Hyundai's...its a thread for them fing02.gif
we do make them in steel or aluminium
most of the time in stock SS would be special order basicly, it's a raised flange that needs to be welded on your actual intercooler or CAi piping it's made for 2.5" piping diameter position the flange in the desired spot, mark all around, cut a "D" shaped hole in your piping to let the MAF sensor part go in the piping,align everything, weld, enjoy wink1.gif |
Can you make one already welded in an alum pipe? Basically to exactly replace the stock MAF?
^^thats what i was getting at, i'd just want it to replace where i have the maf right now. in aluminum, and since i can't tig if you could fab them up it would be great!
By the way, the stock MAF is 3" no? Does the different diameter affect the MAF reading? I know there was a huge thread about this but don't remember the conclusion heh
The stock MAF is 2.75 I believe.
^^ I know denis has been using these for a long time though, test product now.
So what do you say? Can you fab us up replacements and what will it cost? |
