Atelier HP
Sponsor:   Atelier HP
If you can think about it, they can make it for your Hyundai!
http://www.atelierhp.com/ = French (Canada)
http://www.atelierhp.com = English
Alternator Relocation
Old Nov 19, 2008 | 08:29 PM
41willys's Avatar
guys with very large turbos will greatly benefit from this kit (performance wise), as it will allow a less aggressive angle to be made on the downpipe.
Old Nov 19, 2008 | 08:41 PM
Exactly why I did it. And had to fit the dump tube in there also.
Old Nov 20, 2008 | 12:18 AM
Denisst99's Avatar
i solved my belt contact problem today..
so far it's done ;-)
i'll just fix little details to get it to my taste, then i'm posting some pics
Old Nov 20, 2008 | 12:26 AM
tanc's Avatar
Vehicle: 1997 Tiburon
Damn right.
Old Nov 20, 2008 | 12:27 AM
i think if you turbo, this is one of the most to do...cause your A/C is going to rob you of a ponies anyway...
Denisst99 why dont you get a vendor forum on here
Old Nov 20, 2008 | 09:11 AM
Mad_john's Avatar
<div class='quotetop'>QUOTE (41willys @ Nov 20 2008, 12:29 PM) <{POST_SNAPBACK}></div><div class='quotemain'>guys with very large turbos will greatly benefit from this kit (performance wise), as it will allow a less aggressive angle to be made on the downpipe.</div>
Old Nov 21, 2008 | 08:27 PM
Denisst99's Avatar
here's a quick preview of how it will look like...
i re-used the A/C idler pulley to get proper belt contact on the alternator and crank pulleys
made a new rear mount (doh!) and also made a new ''link'' to tie the other side of the alternator the the block itself
i'll try to make a jig and get some costing either this week end or in the beginning of next week....
may we have large downpipes!!!!!!
Old Nov 21, 2008 | 09:15 PM
Cant see how your bracket is but mine is set up almost exactly like that with the AC pulley used for tensioning. Really a great solution for downpipes and not burning up the alternator. Good work! fing02.gif
Old Nov 21, 2008 | 10:15 PM
Denisst99's Avatar
i could go with a regular "slide type" bracket on the bottom to adjust the belt tension and not use the AC idler
but doing so i'm not having enough belt contact on both alternator and crank pulley
anyway,most guy here either have or had AC on their car, or can easily get an idler from a local yard...
Old Nov 22, 2008 | 12:33 AM
tanc's Avatar
^^^ That is the right way to do it. Good work man.
