Can only find an LSD for RD1's
Old 09-28-2016, 07:22 AM
2k1RedTib's Avatar
Vehicle: 2K1 Red Tib
Default Can only find an LSD for RD1's
http://www.kaazonline.com/dbm2050.html
Will these fit RD2's without any major mods? I was under the impression that all those components were pretty much identical between the 2 generations.
Old 10-04-2016, 04:08 PM
Juanra's Avatar
Yes! they are the same for all Beta/Elantra Tiburons.
Old 10-09-2016, 08:36 AM
tdonnell's Avatar
Quaife also has an option that works in our cars. The part number is QDH8B. This is what I've been running for years and I can attest to its durability (I've broken many a gear inside the transmission and the diff just keeps on truckin!). You'll need a Mitsubishi speedometer gear for these also.
