beta 2 5 spd transmission
Old May 15, 2012 | 11:09 PM
Hyunshark21's Avatar
Default beta 2 5 spd transmission
Long time no post, probably since the rdtiburon days... Anyway I did some searching for a transmission swap thread, going from the stock beta 1 trans in rd2 tiburons and swapping in a beta 2 trans from and elantra gt. I remember there being a slight modification, but i cant remember if there was anything else. Any clue what happened to this thread or if there is newer info on this?
Old May 15, 2012 | 11:33 PM
tib _500's Avatar
only thing you have to do is grind off a slight bit of the casing, so the rd mounts will fit. the rest is direct swap. i believe it was optimo that did a write up...so i know its old thread, because he has a diff tib now. it was contained in his beta2 swap thread i believe. he did both at once
Old May 16, 2012 | 06:34 PM
yeah i thought there was a separate thread for it, ill keep looking. Yeah i should be able to make it fit, i just thought there was information about different gear ratios and syncro design.
Old May 17, 2012 | 02:06 AM
tib _500's Avatar
tranny info
https://www.hyundaiaftermarket.org/f..._1#entry614695
tranny swap info
https://www.hyundaiaftermarket.org/f..._jmans__st__40
sorry for slight mis-direction just wrong member in mind i guess
Old May 18, 2012 | 04:08 PM
thanks for the help man!
Old May 19, 2012 | 04:21 PM
i put up pics in the swap thread but the only diffrence is the mounting plate other then that it goes right on
