1st gen tiburon headlights and radiator core support
Old Feb 20, 2003 | 05:48 AM
Emagdnim's Avatar
Default 1st gen tiburon headlights and radiator core support
Hello all, i'm looking for 1st gen tiburon headlights and radiator core support w/ the hoodlatch still attached. If anyone can help me out, thank you. BTW, i have emailed lots of salvaged yards with no help yet. thanks..later
MATT
[ February 23, 2003, 06:42 PM: Message edited by: Emagdnim ]
Old Feb 20, 2003 | 08:51 AM
TiburonJay's Avatar
Vehicle: 2007 Tiburon GT
i think needs i have a passenger headlight that has a small hole in the back mounting....i am gonna have to dig and make sure though
Old Feb 20, 2003 | 09:06 AM
SR can get you the Korean Spec headlights for $170 for the pair. That's much cheaper than any salvage yard or dealer.
Do you just need the vertical brace with the hood latch on it, or do you also need the horizontal braces? Upper or lower or both?
Old Feb 20, 2003 | 09:47 AM
JAWS 021's Avatar
ill sell you mine (headlights)
the pair
100 bucks plus shipping
Old Feb 20, 2003 | 09:49 AM
Emagdnim's Avatar
I need the horizontol brace and the verticle brace with the latch on it. I may be able to do without a new verticle brace, but i do need a horizontal brace for sure. Thanks for the info on the headlights and any future info.
*Edit* Jaws, what condition are they in?
[ February 20, 2003, 04:50 PM: Message edited by: Emagdnim ]
Old Feb 20, 2003 | 10:06 AM
JAWS 021's Avatar
i think i can help you out with the radiator braces... me and random have a hook up here at a local junkyard
Email me
animal3767@aol.com
As far as the headlights
the drivers side is fine... the passenger side is fine too, but is slightly cracked (the part thats on the inside of the engine bay and NOT visible and NOT on the clear plastic)
They have been on my car like that for a full year, and i havent had any signs of condensation
Well let me know man
Old Feb 21, 2003 | 03:18 AM
Jaws021-
All the tibbies in the junkyard near us are gen2's. He needs a gen1 rad-cross-brace, not a gen2. Also, they all have severe front end damage, we would need the parts off a rear ended gen1.
Emagdnim-
What happed to your Tibby? You need BOTH headlights, hood latch, and both the horizontal and vertical cross braces? I take it the whole front end is toast? I'm about 75% sure the lower radiator cross brace is welded on, not bolted on, so I'm not sure if we will be able to get that for you, but I'll call around to see if I can find a gen1 front end in decent shape and go from there.
It might be cheaper for you to buy a "front end" or "front clip" off a wrecked car that was rear ended. You can usually pick them up for under $2000, and you get everything from the firewall forward...engine, tranny, lights, turnsignals, axles..etc.etc.. You can then sell of the parts you don't need (engine, tranny, fenders, hood, etc..etc..)
Old Feb 21, 2003 | 03:41 AM
JAWS 021's Avatar
Random:
Westway isnt my ONLY hook up... there some dude named chris that can help
Im not sure if Emagdim wants to keep his project under raps... but imma try hard *** hell to get him those parts
If only he lived in socal...
BTW Emagdim, if you need the corner lights as well let me know.. ill let you have my stock ones
[ February 21, 2003, 10:42 AM: Message edited by: JAWS 021 ]
Old Feb 21, 2003 | 03:12 PM
Emagdnim's Avatar
Naw its all good man, i was going to keep it under raps untill i finished, but it doesn't really matter...thanks though. I'm really gathering parts for the 1st gen front end swap onto my 2nd gen...soooo if the bottom peice is welded on, do you know if its the same as the one from the second gen, it looks similar. If it is the same, all i need is the top peice. So if you have any ideas, i'm open. Its something i'm very serious about doing so i really want to have as few problems as possible. Thanks again for your help guys, please keep in touch....later
MATT
BTW: Jaws, I think i'm going to go ahead and buy clear corners strait up unless i run out of money. I'll let you know on that one....thanks
[ February 21, 2003, 10:16 PM: Message edited by: Emagdnim ]
Old Feb 22, 2003 | 04:11 AM
FlyRyde's Avatar
I quite possibly could be "some guy Chris"... either way I'll check my connect as well. Me and you will actually be in the same boat. Except for the rear tail lights you'll have a similar setup as me. 1st gen body, 2nd gen CAR!
