Vendor's Booth: General
Weekly Specials - Good through 5/29 (4:30 Central)
Old May 27, 2009 | 11:25 PM
kingpinelectronics's Avatar
Vehicle: 2008 Hyundai Tiburon
Red face Weekly Specials - Good through 5/29 (4:30 Central)
K9-SOMBRA Vehicle Alarm System with Keyless Entry, Dual Zone Shock Sensor and Two Remotes: $60 SHIPPED
PRODUCT CONTENTS:
Two New 1-Button RFID Transmitters.
Locks / Unlocks Doors when Transmitter is within range (RFID).
Arms / Disarms when Transmitter is within range (RFID).
Automatic Anti-Carjacking Mode (RFID).
Automatic Keyless Entry.
On-Board Door Lock / Unlock Relays.
On-Board Starter Disable Relay (N/O or N/C).
Option for wo Additional Immobilizer Circuits.
Easy Valet.
Pre-Warning.
Selectable Siren or Horn Honk Output +.
Dual Flashing Light Outputs.
RFID SYSTEM FEATURES:
With the new RFID system, the remote control functions become automatic. The system will automatically lock and unlock the vehicle's doors when you come within range, as well as activate the car's anti-hijacking feature (if programmed).
All of this is possible without having to press any buttons. Or if you prefer, the RFID feature can be turned off, and the alarm may be operated conventionally by using the remote controls.
F2.200 200 Watt 2-Channel High Power Amplifier: $65 SHIPPED
This is a GREAT amp to run a set of components or high end 2/3-Way speakers!
200W, 2 Channel Power Amplifier, High/Low Crossover
· Low pass crossover 120Hz (fixed)
· Variable input gain control
· Power and protection LED indicators
· Line and speaker level inputs
· Chrome plated RCA connectors and screw terminals
· Frequency response: 12Hz - 22kHz (+/- 3dB)
Max power 2 ohm 100W X 2
RMS power 4 ohm 50W X 2
Signal-to-noise ratio 90db
THD at RMS output 0.01%
Damping factor 125+
Dimensions (9” W x 2-1/16” H x 5-1/8 “ L)
CW350 400 Watt 4-Channel Power Amplifier: $85 SHIPPED
LINE AND SPEAKER LEVEL INPUTS
VARIABLE GAIN CONTROLS
POWER LEDS
POWER, 2 OHM 100w x 4
RMS POWER, 4 OHM 50w x 4
SIGNAL-TO-NOISE RATIO 90dB
THD 0.05%
DIMENSIONS: 9-11/16”W x 2-3/8”H x 7-3/4"L
D-800.2 1600 Watt 2-Channel Amplifier: $115 SHIPPED
DIABLO 2-CHANNEL MOSFET AMP FEATURES
· Trimode operation
· Bridgeable
· Remote subwoofer level control
· 0 to +18dB variable bass boost
· MOSFET power supply
· Variable low pass crossover
· Variable high pass crossover
· Input gain control
· Input sensitivity selector
· Power and protection LEDs
MAX POWER, 2 OHM 800w x 2
RMS POWER, 4 OHM 260w x 2
MAX BRIDGED POWER, 4 OHM 1600w x 1
SIGNAL-TO-NOISE RATIO > 105 dB
THD 0.01%
DIMENSIONS: 11”W x 2-5/16”H x 15-3/16”L
GRLA1800/2 1800 Watt 2-Channel Mosfet Power Amplifier: $155 SHIPPED
RSM @ 4ohms 300w x 2
RMS @ 2ohms 380w x 2
Bridged @ 4ohms 760w x 1
2/4 Channel SPECS:
• Brilliant Silver Texture Coat Finish
• MOSFET Power Supply
• Pulse Width Modualtion Circuitry
• Three-Way Protection Circuitry (short, thermal & overload)
• 2 Ohm Stereo, 4 Ohm Bridged Stable
• Tri-Mode Capable
• Selectable Hi/Full/Low Pass Crossovers
• Pre-Amp Outputs (ex. 1200/4)
• Dash Mount Remote Gain Control (2 ch. models)
• 200mV - 6V Low Level Input Sensitivity
• Variable 12dB 30-250Hz LPF
• Variable 12dB 50-500Hz HPF
• Variable 0-12dB 45Hz Bass Boost
• Variable 12 dB 15-50Hz Subsonic Filter (ex. 800/2)
• Frequency Response: 10Hz - 30kHz
• Signal-to-Noise Ratio: 97dB
• Total Harmonic Distortion: .02%
• 4 ga. Power & 8 ga. Speaker Terminals
ASA-600.2X 600 Watt 2-Channel Amplifier w/ FREE TSUNAMI 8ga Amp Kit!!!: $175 SHIPPED
ASA Series 2, 4, 5 Channel Class A/B Amplifiers Features:
2-ohm Stereo/ 4-ohm Mono Stable* for multiple connection versatility
MOSFET Power Supply for the most efficient and distortion free sound reproduction
Variable 12dB, High/Low Pass Electronic Crossover for infinite system applications
Variable Bass Boost that lets you get the most out of your subwoofers
Optional Remote Gain Control gives the listener the option of turning the subwoofers up or down
* A/B Mono blocks are stable at 2-ohm Mono
SPECIFICATIONS:
• 4 ohm Power : 150W x 2
• 2 ohm Power : 300W x 2
• 4 ohm Mono Power : 600W x 1
• Peak Power : 1200W
• Total Harmonic Distortion : <0.05%
• Frequency Response : 20Hz - 22,000Hz
• S/N Ratio : >94 dB/W/M
• Damping Factor : >150
• Input Sensitivity : 0.5 - 4.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 40Hz - 250Hz
• Low-Pass Crossover Freq : 40Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 40Hz
• Dimensions : 13.7" x 9.3" x 1.9"
• Dimensions : 350mm x 238mm x 48mm
IB-AK01 Complete 1/0 Gauge Amp Kit For Multiple Amp Installations: $75 SHIPPED
17' blue power wire, 8' blue power wire, 6' silver ground cable, two 17' RCA cables, 20' turn-on wire, 15' speaker wire, ANL fuse holder, ANL fuse holder/distribution block with dual fuses.
For payment just send the amount and in the notes put what you are ordering. My paypal address is jared@kingpinelectronics.com
Old May 28, 2009 | 06:31 AM
Damn good prices! Hop on these people!
