Weekly Specials - Good through 5/29 (4:30 Central)
<div align="CENTER">http://www.savinglots.com/pimages/K9SOMBRA.jpg
<span style="font-size:24pt;line-height:100%">K9-SOMBRA Vehicle Alarm System with Keyless Entry, Dual Zone Shock Sensor and Two Remotes: <u>$60 SHIPPED</u></span> <span style="font-size:14pt;line-height:100%">PRODUCT CONTENTS:</span> Two New 1-Button RFID Transmitters. Locks / Unlocks Doors when Transmitter is within range (RFID). Arms / Disarms when Transmitter is within range (RFID). Automatic Anti-Carjacking Mode (RFID). Automatic Keyless Entry. On-Board Door Lock / Unlock Relays. On-Board Starter Disable Relay (N/O or N/C). Option for wo Additional Immobilizer Circuits. Easy Valet. Pre-Warning. Selectable Siren or Horn Honk Output +. Dual Flashing Light Outputs. <span style="font-size:14pt;line-height:100%">RFID SYSTEM FEATURES:</span> With the new RFID system, the remote control functions become automatic. The system will automatically lock and unlock the vehicle's doors when you come within range, as well as activate the car's anti-hijacking feature (if programmed). All of this is possible without having to press any buttons. Or if you prefer, the RFID feature can be turned off, and the alarm may be operated conventionally by using the remote controls. http://www.dragondistributing.com/pictures/f2200.jpg <span style="font-size:24pt;line-height:100%">F2.200 200 Watt 2-Channel High Power Amplifier: <u>$65 SHIPPED</u></span> This is a GREAT amp to run a set of components or high end 2/3-Way speakers! 200W, 2 Channel Power Amplifier, High/Low Crossover Low pass crossover 120Hz (fixed) Variable input gain control Power and protection LED indicators Line and speaker level inputs Chrome plated RCA connectors and screw terminals Frequency response: 12Hz - 22kHz (+/- 3dB) Max power 2 ohm 100W X 2 RMS power 4 ohm 50W X 2 Signal-to-noise ratio 90db THD at RMS output 0.01% Damping factor 125+ Dimensions (9” W x 2-1/16” H x 5-1/8 “ L) http://www.dragondistributing.com/pictures/cw350.jpg <span style="font-size:24pt;line-height:100%">CW350 400 Watt 4-Channel Power Amplifier: <u>$85 SHIPPED</u></span> LINE AND SPEAKER LEVEL INPUTS VARIABLE GAIN CONTROLS POWER LEDS POWER, 2 OHM 100w x 4 RMS POWER, 4 OHM 50w x 4 SIGNAL-TO-NOISE RATIO 90dB THD 0.05% DIMENSIONS: 9-11/16”W x 2-3/8”H x 7-3/4"L http://www.bossaudio.com/main/wsc_co...2000053151.jpg <span style="font-size:24pt;line-height:100%">D-800.2 1600 Watt 2-Channel Amplifier: <u>$115 SHIPPED</u></span> <span style="font-size:14pt;line-height:100%">DIABLO 2-CHANNEL MOSFET AMP FEATURES</span> Trimode operation Bridgeable Remote subwoofer level control Line and speaker level inputs 0 to +18dB variable bass boost MOSFET power supply Variable low pass crossover Variable high pass crossover Input gain control Input sensitivity selector Power and protection LEDs MAX POWER, 2 OHM 800w x 2 RMS POWER, 4 OHM 260w x 2 MAX BRIDGED POWER, 4 OHM 1600w x 1 SIGNAL-TO-NOISE RATIO > 105 dB THD 0.01% DIMENSIONS: 11”W x 2-5/16”H x 15-3/16”L http://www.dragondistributing.com/pictures/grla2200.jpg http://splusa.net/images/GORILLA1.jpg <span style="font-size:24pt;line-height:100%">GRLA1800/2 1800 Watt 2-Channel Mosfet Power Amplifier: <u>$155 SHIPPED</u></span> RSM @ 4ohms 300w x 2 RMS @ 2ohms 380w x 2 Bridged @ 4ohms 760w x 1 <span style="font-size:14pt;line-height:100%">2/4 Channel SPECS:</span> • Brilliant Silver Texture Coat Finish • MOSFET Power Supply • Pulse Width Modualtion Circuitry • Three-Way Protection Circuitry (short, thermal & overload) • 2 Ohm Stereo, 4 Ohm Bridged Stable • Tri-Mode Capable • Selectable Hi/Full/Low Pass Crossovers • Pre-Amp Outputs (ex. 1200/4) • Dash Mount Remote Gain Control (2 ch. models) • 200mV - 6V Low Level Input Sensitivity • Variable 12dB 30-250Hz LPF • Variable 12dB 50-500Hz HPF • Variable 0-12dB 45Hz Bass Boost • Variable 12 dB 15-50Hz Subsonic Filter (ex. 800/2) • Frequency Response: 10Hz - 30kHz • Signal-to-Noise Ratio: 97dB • Total Harmonic Distortion: .02% • 4 ga. Power & 8 ga. Speaker Terminals http://splusa.net/images/GORILLAF1.jpg http://www.dragondistributing.com/pictures/asa6002x.jpg <span style="font-size:24pt;line-height:100%">ASA-600.2X 600 Watt 2-Channel Amplifier w/ FREE TSUNAMI 8ga Amp Kit!!!: <u>$175 SHIPPED</u></span> <span style="font-size:14pt;line-height:100%">ASA Series 2, 4, 5 Channel Class A/B Amplifiers Features:</span> 2-ohm Stereo/ 4-ohm Mono Stable* for multiple connection versatility MOSFET Power Supply for the most efficient and distortion free sound reproduction Variable 12dB, High/Low Pass Electronic Crossover for infinite system applications Variable Bass Boost that lets you get the most out of your subwoofers Optional Remote Gain Control gives the listener the option of turning the subwoofers up or down * A/B Mono blocks are stable at 2-ohm Mono <span style="font-size:14pt;line-height:100%">SPECIFICATIONS:</span> • 4 ohm Power : 150W x 2 • 2 ohm Power : 300W x 2 • 4 ohm Mono Power : 600W x 1 • Peak Power : 1200W • Total Harmonic Distortion : <0.05% • Frequency Response : 20Hz - 22,000Hz • S/N Ratio : >94 dB/W/M • Damping Factor : >150 • Input Sensitivity : 0.5 - 4.0 volts • Crossover Slope : 12 dB • High-Pass Crossover Freq : 40Hz - 250Hz • Low-Pass Crossover Freq : 40Hz - 250Hz • Variable Subwoofer EQ : 0/+18 dB • Subwoofer EQ Frequency : 40Hz • Dimensions : 13.7" x 9.3" x 1.9" • Dimensions : 350mm x 238mm x 48mm http://www.deffaudio.com/store/images/ibak01.jpg <span style="font-size:24pt;line-height:100%">IB-AK01 Complete 1/0 Gauge Amp Kit For Multiple Amp Installations: <u>$75 SHIPPED</u> </span> 17' blue power wire, 8' blue power wire, 6' silver ground cable, two 17' RCA cables, 20' turn-on wire, 15' speaker wire, ANL fuse holder, ANL fuse holder/distribution block with dual fuses. For payment just send the amount and in the notes put what you are ordering. My paypal address is jared@kingpinelectronics.com</div> |
Damn good prices! Hop on these people!
