Vendor's Booth: General
wanting the turbo
Old Jan 29, 2003 | 09:57 AM
jerseytiburon's Avatar
Default wanting the turbo
i am going to buy the cnk turbo soon but i want to know what else needs to be done to a pretty much stock 2L tib. thanks in advance. wink
Old Jan 29, 2003 | 04:03 PM
CNK Performance's Avatar
Nothing at all --- the kit is designed to run on a stock tib engine as all the components are supplied in the kit.
ECU - I will be testing finally by the end of this week. I will be including this into the kit once approved and successfully tested.
Old Jan 30, 2003 | 02:19 AM
good stuff!
i'll need gauges though right?
Old Jan 30, 2003 | 05:13 AM
Yes you will ---
Most Important ones:-
Oil Pressure
Boost
Fuel pressure - specially if you run N2O
EGT - but not a necessity
Old Jan 30, 2003 | 01:04 PM
BlueGT's Avatar
Vehicle: 2004 Tiburon GT
You might want to get a better clutch too.
Old Jan 30, 2003 | 01:17 PM
BlueGT:
why?
Old Jan 30, 2003 | 02:00 PM
sharkey9883's Avatar
your stock clutch will start slipping when the same crankshaft sends over double the stock horsepower to it. actually, it will fry.
Old Jan 31, 2003 | 06:15 AM
Old Feb 4, 2003 | 03:48 PM
Aoshi's Avatar
So how goes this ECU project?
Old Feb 5, 2003 | 05:00 AM
It goes well --- Lostbouys Elantra started tonite about 45minutes ago, after I built the engine and installed the CNK 300HP kit ...
The engine will be run in by the end of the week if all goes well, and then the ECU will be tested - we had a few small delays but all sorted now - we can continue.
LOTS of Pictures coming soon!
