Vendor's Booth: General
VHR Clutch
Old Dec 30, 2004 | 05:04 PM
UltraTibby's Avatar
Default Re: Speed Factor SS Equal Length Turbo Manifold GB
I just got my kit in today. Everything looks great. I just have one question though. For an 01 Tiburon do you need to use the spacer on the flywheel or is it not needed?
Old Dec 31, 2004 | 12:52 AM
Denisst99's Avatar
Default Re: WTF is wrong with my car
the spacer is there to math the flywheel to the crankshaft,
in your case the spacer shoul be needed
you'll be a 100% sure when you'll install your new parts ;-)
Old Dec 31, 2004 | 06:29 AM
UltraTibby's Avatar
Default Re: Two color Paint?
Not to sound like an amature but how do you know if you need to use the spacer?
Old Jan 3, 2005 | 11:19 PM
Denisst99's Avatar
Default Re: exhaust sound clips
simple:
97 to 07-99 have a 41mm crank pilot
07-99 and up have a 35 mm crank pilot
the crank pilot is what is centering your flywheel on the crank
so if your in doubt, just take out a ruler to measure it or simply just try to put the spacer on your crank, if it fits then it's needed
Old Jan 10, 2005 | 11:30 PM
2race4REAL's Avatar
Denisst99
Thanks for answering all those questions.
I have to ask VHR in order to get right answer, since I never installed anything of my own.
It would of took me longer to post any reply...
Old Jan 11, 2005 | 09:26 AM
UltraTibby's Avatar
Thanks Rick! I wont be installing this for another few weeks. But if you can verify when you can about the spacer it would be great.
Old Feb 3, 2005 | 12:04 PM
UltraTibby's Avatar
Hey Rick, just checking to see if you have had a chance to check with VHR on wether the spacer would be needed for Gen2's.
I have seen the same thing that Denisst wrote about the 35mm crank pilot being on the 07/99 and up if that helps out at all. I just want to be sure one way or the other before I go and start taking things apart.
Old Feb 4, 2005 | 12:00 PM
2race4REAL's Avatar
QUOTE (UltraTibby)
Anything beyond RD2 will need spacer.
The model year is somewhat hard to determine, since Korea release the car sooner than oversea.
RD1 was released in Korea 96, and I saw the car back in 95 at Hyundai Nam Yang Man R&D proofing ground testing suspension.
Old Feb 4, 2005 | 11:20 PM
Denisst99's Avatar
if you have a 2001 tibby you need the spacer for sure
one thing i'd like to add,
in my case,fidenza aluminium flywheel (for 99 and lower) and a 2001 engine i needed the spacer,problem was, bolts were too short,tread engagement was very minimal (around 1/8"),so i had to use longuer flywheel bolts
i haven't verified if it's the case with the VHR flywheel,it could be thinner in the bolt area,
so be sure to double check that better be safe then sorry when dealing with a flywheel.
