Vendor's Booth: General
Speed-Factor Turbo Kit Contents and Prices
Old Sep 28, 2004 | 04:57 PM
ONLY1DB's Avatar
Default Re: for your viewing pleasure
does it work with the beta II it as a MAP sensor rather then a MAF
Old Sep 28, 2004 | 08:14 PM
Dweet's Avatar
Default Re: newbie limey!
yeah but if you want high boost you'll want to upgrade your MAP sensor
Old Oct 22, 2004 | 05:26 PM
Mister_Sinister's Avatar
Default Re: Custom gauges
Hey Tim, a couple of questions:
1:If I wanted to get the Extreme kit with the Equal Length manifold, what else would I need to get?
2:Sorry, this is kind of a n00b question, so here goes. With the external wastegate, the waste is vented into the atmosphere, correct? If so, I'm assuming that's not street legal, so would you be able to go ahead and have it vent into the downpipe?
Thanks for the help man.
Old Oct 22, 2004 | 05:35 PM
Casper's Avatar
Default Re: 04 CVVT Turboed - Speed Factor kit
From what ive read, you need to vent into the downpipe due to emissions / loudness so yes, it is possible (anything is possible actually, as long as you have the right tools smile.gif )
Old Nov 14, 2004 | 04:04 PM
PSITurbulence's Avatar
Default Re: FS : eibach lowering springs and other stuff
I have a Beta II, lest say i were to get the basic kit, what PSI level would be safe like 6psi?
Old Nov 14, 2004 | 04:51 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: GB Requests
Yes 6 psi will be fine, do a search on here man that has been covered a number of times. Tim (SpeedFactor) is running over 13 psi on his elantrawagon that has the same engine.
