Speed-factor Fix It Thread
Vehicle: Had 96 Elantra Wagon
Ok this is not a place to try and bash or blame, all I want is post for parts you are owed. If you ordered something and did not recieve it. If you have a bad turbo we will work on getting it replaced.
I will try and check this thread at least twice a day, so please if you post give me sometime to be able to check before posting again.
Thanks.
Thanks.
Keep it civil kids, I will delete off topic posts here. You have other issues, take them elsewhere. Tim is trying to get this crap finished to move on.
Warnings WILL BE ISSUED. Feel free to post if you still have an outstanding problem.
Stickied.
Stickied.
Guest
Posts: n/a
hey tim,
i am sure you already know what you said you would fix/replace..
you told me you would get my turbo fixed since it was blowing oil and bad from day one, but you didnt use same turbo guy or something.. that shouldnt be my problem. so what are we going to do about that..
you also owed me that new intake, because i had to hack my other one up to get the bosch actuator in there, and you said you would send me a new one that sat in battery tray.
you also said you would build me a knew wastegate dump because i had to crush mine almost flat to clear the turbo dump pipe..
that would be it, since i fixed all the other problems..
Problems I had with my kit that I had to modify or replace all together would you replace them?
Downpipe
Hot side Intercoolerr piping
T3 Turbo. Wasn't a real Super 60
No intake piping for turbo
Had to get Both Manifolds of you that I paid for Re-Welded.
The Rubber couplers you included with my kit that came from the Plumbing section at your local Home depot Melted, Cracked, ETC.
Downpipe
Gary, your kit was made 3 years ago approx.
At the time the kit came with the rubber couplers.
The manifolds would have just had to be sent back to me for repair and I would have paid shipping, and same for the Downpipe, and Intercooler piping.
The Turbo was used problem free since you had the kit, and you told me the wheels spec'd right.
I will send you the intake pipe if you want.
Shoot me a pm if you want the Intake.
Nate I will shoot you a pm with the info for the turbo. I should have something no later than Monday for you on that.
When I purchased the kit I was told Silicone couplers came with because you know rubber ones will not hold up with the heat!
I am know longer using the downpipe or Hot side intercooler piping.
You can send me the right fitment HOT SIDE intercooler piping, Intake Pipe and Silicone Couplers. If your willing to "fix it". I will send back the wrong hotside piping, and rubber couplers when I recieve the correct parts from you.
