Vendor's Booth: General
Smoke Tail Light Covers
Old Oct 13, 2007 | 07:33 PM
  #61
butters's Avatar
^^^^agreed.... i want them but i thought you could get them for cheeper then 60 somethin
Old Oct 13, 2007 | 07:51 PM
  #62
LNHeart's Avatar
I would like to get them also but would also like some close up pics. If i would get them i would put them over the red oem ones.
Old Oct 13, 2007 | 07:53 PM
  #63
the tails are about 2mm thick.. unless you get right on top of them you couldn't even tell it was a cover. they are made for a replacement.
they are the EXACT same size as the stock lens. just bake, pop old off, glue new on, if you are replacing them..
for covers, just peel back tape and stick.. you now have tinted tails. fing02.gif
heres a kinda close up.. the tail is sticking out, cuz its not bolted in, so i wouldnt get bondo on it while workin on car.
heres another
and another
Old Oct 13, 2007 | 08:05 PM
  #64
butters's Avatar
i want them to be way darker than that though... you stuck them on correct? i want to know if it would be darker to replace the stock ones in the oven like you said
Old Oct 13, 2007 | 08:21 PM
  #65
no, if you used them as replacements they would be alot more se thru.
if you want them darker, take em to a body shop and have them tint them. then enjoy when you get pulled over lol. fing02.gif
Old Oct 13, 2007 | 08:49 PM
  #66
butters's Avatar
haha ya i know but im not worried about it because everyone around here has them and there real real black and the headlights ones to..
Old Oct 15, 2007 | 10:15 AM
  #67
QUOTE (butters @ Oct 13 2007, 03:14 PM)
i would buy the covers if anyone has any or if you can get some.. PM se someone please if they know
Are you a moron or can you just not read? The links to the lenses are like 3 posts up from yours.
QUOTE (Ericy321 @ Oct 13 2007, 07:15 PM)
Can these actually be used as either? I mean will they fit right into the ridge where the stock one sits? Id like to see some close up installed pics.
You can use them as either, I thought I had said that somewhere. When you get the OEM ones off, you'll have to silicone/epoxy these in place I believe.
QUOTE (butters @ Oct 13 2007, 07:33 PM)
You can get them cheaper if you can find them used, or maybe someone with a set that never installed them.
