Vendor's Booth: General
Reprogrammed ECU
Old Jan 27, 2003 | 09:45 AM
Solo-Baric's Avatar
2race4REAL:
4doorGL:
It is possible to reprogram the stock ECU and we have the tools to do it.
We are currently exploring them and working out some tuning maps and such.
I know a few companies in Korea (all of which we work with) have the capability as well.
WE at REAL CO. also known as Speed Mind in Korea have supplied to all of those companies you've visited including DTM (Kim Tae Ha)and Power Best. We have 90% market share in Korea selling re-program tools.
4doorGL
We've posted some informations in HP forum once, and our topic was close instantly. I hope you don't post commercialize issue in our own forum unless it is in other forum's in Hyundai Aftermarket.
http://www.race-real.com/proinfo/proinfo022.html
the reason you post was probally locked is because you didn't contact rob (4doorgl). there is a no advertising rule on hp unless you contact an admin. so please email rob@hyundaiperformance.com and see if you 2 can work somthing out!
Old Jan 28, 2003 | 10:29 AM
2race4REAL's Avatar
O.K. Solo-Baric
Thanks.
Old Jan 29, 2003 | 04:20 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
Ok. What is the 'special part' needed and how can I tune the ECU myself?
Old Jan 29, 2003 | 05:06 PM
Shadohh's Avatar
I Want an ECU reflash that can handle 440cc injectors at idle.
Can you guys do this?
On a US spec ecu? for a 2000 tiburon ?
Old Feb 2, 2003 | 03:19 PM
Hyundaifixer's Avatar
I have the ECM upgrade that Real Co. Makes. My car was the one that they did the final testing on. I like it.
Props to Rick and Real Co.
[ February 11, 2003, 10:03 PM: Message edited by: Hyundaifixer ]
Old Feb 2, 2003 | 03:31 PM
So you're putting 162.2 HP & 166.9 Torque to the ground with what mods?
The ECU and what else?
How much did it cost?
EDIT: NM, it's a 03.
Ehh...
[ February 02, 2003, 10:32 PM: Message edited by: REDZMAN ]
Old Feb 2, 2003 | 03:42 PM
Yeah...I'm thinking that my exhaust might be a little Too open. I'm going to play with different size pipes and see what happenes.
Oh yeah... AEM CAI, Cuatom Cat back and ECM tuned on the Dyno.
[ February 02, 2003, 10:44 PM: Message edited by: Hyundaifixer ]
Old Feb 2, 2003 | 05:43 PM
JAWS 021's Avatar
Shadohh:
Yup they can do this...
Old Feb 2, 2003 | 06:41 PM
Shadohh's Avatar
well...
CAN and WILL are two different things.
what do I NEED to do to get a WILL.
and how soon and at what price.
Old Feb 3, 2003 | 08:34 AM
2race4REAL's Avatar
Shadohh
For 2000 yr. Tiburon, it is not reflash type. Although we can do custom re-map, we avoid doing each customer's spec at the moment.
For custom ECU, we need to see the setup of hardwares, dyno data, and A/F ratio. Therefore, we only work on base of few kits currently in this market like Alpine supercharger and turbocharger kit using our system without 5th injectors and piggyback.
If you have different setup from other company, we don't do base on larger injectors and rpm adjustments only.
