Vendor's Booth: General
New! 3 Verticle Door Kits For Under 650 Dollars!
Old Apr 4, 2006 | 11:44 PM
landcruiser06's Avatar
I just got a new line of Verticle Doors
Gravity Upright Door System Verticle Door----$550 dollars SHIPPED!!!
Gravity Upright Door System will make your car, truck, or SUV stand out in a crowd. The new design allows doors to swing up to 90 degrees. Do not settle for kits with inadequate door movement! Gravity advanced universal design insures proper fitment and a long life of smooth operation. To insure maximum quality each kit is CAD/CAM designed. Kit Includes: (2) Upright Door Hinges (4) 150lb nitrogen gas struts w/steel metal tips, all mounting hardware and brackets, and detailed instructions.
Be aware of the cheap imitations sold from other companies offering a low quality hinge which will bend and break due to every day use. Purchase the gravity kit with ease and separate yourself from the rest with an innovative look to your ride. Our hinge system provides the most door clearance allowable, so you wouldn't have to crawl in your vehicle like with most hinges out in the market today. Buy the best with full confidence. The revolutionary gravity vertical upright door hinge system.
Full Benefits from our gravity upright vertical door hinge system
90 Degrees of Full Door Movement
CAD/CAM Design
Compatible With Shave Door Kits & Remote Operation
Smooth & Easy Door Operation
Anti Wobble Design
Detailed Instructions
Patent Pending
Eliminates Poor Room To Enter & Exit Of Vehicle
Heavy Duty Bushings On Moving Parts
Limited Lifetime Warranty
3-4X Stronger Than Leading Competitor
Hardened Steel Design
Designed For Universal Fit & Quick Install
Keeps Doors Straight Up
Eliminate Doors Hanging To The Side
Totally reversible
4 nitrogen gas struts with total of 600lbs of total force
5 adjustable stop points allows for custom look and operation
Heavy Duty Steel Construction
Lifetime show quality finish
Eliminates Door Seal Leaks
Paintable Surface & Will Not Flake Off Like Others
Anti Corrosive Coating
Maintains Factory Door Seal
Maintains factory safety, accessories & function
Up to 90 degrees Vertically
Up to 25 degrees Horizontally
Fits any vehicle
Works on all OEM latches & accessories
Amazing Results
Scissor-Slide Vertical Lambo Doors----$500 dollars SHIPPED!!!
Scissor-Slide Vertical Lambo Door kit is designed for a universal fit and easy installation. The kit works by opening the door a little to the side and swing it up. It swings up 90 degrees so you don't have to crawl into the car, you simply open it, get in, and close it. When are you are ready to come out then open it again and get out without breaking your back. The vertical door system has four adjustable points on the hinge allows the doors to have a unique look. The kit is 100% CNC machined using 4130 chromyl steel construction. The kits have electrolyses nickel plated for corrosion protection and show quality. It includes four 150lbs struts, door hinges, adjustable brackets, instructions and all hardware required to install the kit.
Manual Kit
(2) Hinges
(4) 150lb Gas Struts
All Necessary Hardware
Installation Instructions
Universal Razor Vertical Lambo Door Kit System - 90 degrees doors-----$650 dollars SHIPPED!!!
Razor Vertical Door kit is designed for a universal fit and easy installation. It will lift the doors up to a 90 degrees vertical direction. The door will be able to stay straight up instead of having them hanging on the side as you would have from a vertical door inc., glide or specific bolt-on kit. It comes with dual nitrogen gas struts that rate 300lbs lifting force per door. The four adjustable points on the hinge allows the doors to have a unique look. The kit is 100% CNC machined using 4130 chromyl steel construction. The kits have electrolyses nickel plated for corrosion protection and show quality. Our Lambo Door kit maintains factory standards, accessories and functions. The kit can be painted to the factory color of the car. The installation is completely reversible and it comes with a limited lifetime warranty. The doors will go up 90 degrees and 25 degrees horizontally.
Will they fit your car? Yes the kit is universal it can either be welded or bolted on (drilling required) to your car. It has a unique design, so no matter what kind of car you have it will still fit without a problem.
CAD/CAM Design
Anti Wobble Design
Patent Pending
Totally reversible
1 Year Warranty on the door Struts
Lifetime warranty on the door hinges and all parts.
For more Exterior Bodyparts and Verticle door kits
http://www.mimousa.com/home.asp?dir=...at=6&sub_id=32
Old Apr 5, 2006 | 08:52 AM
demon_fox's Avatar
Vehicle: 2000 hyundai tiburon
anyone have one of these on our cars? if so please post pics. i would like to see. before i waste my money lol
Old Apr 5, 2006 | 12:07 PM
I am getting my money together for the Gravity kit I will post some pics when I get it installed. Everyone I have asked seems to be very pleased with them.
Old Apr 5, 2006 | 12:40 PM
Wow... will these fit our cars? Yeah you would have to provide some good pics and description of the quality to buy me out. i'm going to wait... sounds interesting though, i mean that's an awesome price.
i also have a co-worker who would jump on this. Chevy S-10 1996. check and see if you have anything that will work.
Old Apr 5, 2006 | 12:51 PM
Tibracer33's Avatar
Vehicle: 2001/hyundai/tiburon
I am very interested but waiting till someone gets one and tells how they are first.
Old Apr 5, 2006 | 02:26 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
what are the differences between those kits?
pics will be great
Old Apr 5, 2006 | 03:04 PM
any of these kits bolt on?
Old Apr 5, 2006 | 09:20 PM
You will not find a direct bolt on for the Tiburon-I also sell Autoloc, GT Factory, and 90 degree verticle doors which retail over 1500.
If you read past the Title and price you can see the difference between the kits are Shock size, what metals are used, the Gravity has a LIFETIME WARRENTY ON ALL HARDWARE, and much more. Thats the difference
Please read information, if there is something not covered then ask a question about the kits.
The kits are universal-which means they fit all cars with some drilling required-if you pay 2000 or 500 you will HAVE to do a little drilling.
http://www.mimousafiles.com/prods/gt...nstalled-2.jpg
Here are the pics from MIMOUSA
Old Apr 5, 2006 | 10:33 PM
col96fx's Avatar
Vehicle: Hyosung GT650
QUOTE (Greatblackshark @ Apr 6 2006, 12:50 PM)
http://www.rdtiburon.com/index.php?showtopic=6482
Old Apr 6, 2006 | 01:37 AM
FlyRyde's Avatar
Let me know if you want a hook up on VDI kits as they're the most expensive on the market, and I go DEEP with those guys. I'll give pretty crazy wholesale prices for your website.
