Vendor's Booth: General
GB ends May 28th : TigerLily products
Old May 11, 2004 | 04:29 PM
racereal's Avatar
20% off from suggested retail price base on Los Angeles, CA USA.
Deliery is extra by any form of carrier request worldwide.
Paypal add 3% for domestic, 4% for international.
GB ends May 28th.
If there is backorder item, I will post here and will lock in the price until available.
TIGERLILY NEW PRICE LISTS
HIGH CAMS
Hi-Camshaft HYUNDAI Tiburon & Tuscani 2.0 DOHC
Hi-Camshaft 272(in/ex) $1,070
Hi-Camshaft 282(in/ex) $1,287
272 in-cam / 282 ex-cam $1,287
272 Sintered Hollow Cams (in/ex) $1,287
HYUNDAI Accent 1.5 DOHC In-cam only 268 $743
HYUNDAI V-6 2.7 In-cam only 268 $1,287
FORGED PISTON
*Comp. : 8.5:1(Bore 82mm) $890
*Comp. : 11.0:1(Bore 83mm) $1,287
*Comp. : 13.0:1(Bore 83mm) $1,587
CAST PISTON
1.0mm oversize $299
2.0mm oversize $476
1.0mm oversize, Hi-*comp(13.0:1) $563
Lightweight Normal size $299
*Comp. 8.5:1(Bore, 82mm) $299
HYUNDAI Accent 1.5 DOHC 1.0mm, Hi-*comp. oversize $299
HYUNDAI Tuscani V-6 2.7 Lightweight, Hi-*comp, Normal size $644
HYUNDAI Tiburon & Tuscani 2.0 DOHC Lightweight, Normal size $299
SPORTS GEAR
(Closed Ratio) Tiburon & Accent
1st, 2nd(2.929/2.053) $1,227
3rd 1.538 $324
4th 1.241 $324
5th 1.031 $324
F.G.R(4.412, 4.188) $594
INJECTORS
350cc/min (1ea) $125
550cc/min (1ea) $170
CLUTCH
Clutch cover $237
Clutch disc $258
BIG BORE THROTTLE BODY
Tiburon Φ58 $179
, with auto cruise $235
Tiburon Φ65 $198
, with auto cruise $255
Tuscani 2.0 Φ58, with auto cruise $245
Tuscani 2.7 Φ60, with auto cruise $357
Accent Φ48 $228
Shuma (KIA) with auto cruise $235
Sonata with auto cruise $235
HEAD GASKET
2.08t(for T/C engine) $237
0.37t(for N/A engine) $50
2.08t(for T/C eninge) $237
0.42t(for N/A engine) $50
Exhaust gasket(4 layers) $36
VALVE SPRINGS
Single Coil spring $320
Dual coil spring $564
OIL PUMP
Oil Pump $237
Relief spring $20
Oil Pump $237
CON RODS
Titanium $2,500
Cr-Mo $1128
CRANKSHAFT
HYUNDAI Tiburon & Tuscani 2.0 DOHC Lightweight & balanced $1,050
*Comp. : Compression Ratio
