Vendor's Booth: General
CNK's 350cc Injectors...
Old Jan 6, 2003 | 09:03 AM
QS's Avatar
QS
Default CNK's 350cc Injectors...
will they work on a 1.6L Accent w/out modification?
Old Jan 7, 2003 | 04:19 AM
CNK Performance's Avatar
No it won't work -
You will need to re-calibrate the ECU and air flow meter to fuel the larger injectors.
Usually MAF's and injectors are sized in conjunction to the air flow the MAF can measure related to the size of the injectors and the CC's they can produce.
If you want to run the larger injectors, I would use either a piggy back system or a programmable stand alone system depending on your setup. BUT on their own - they WILL NOT WORK.
Old Jan 7, 2003 | 04:55 AM
skierd's Avatar
Vehicle: 1997 accent L
I think he was refering to the physical fit, NOT the needed calibrations. wink
Old Jan 7, 2003 | 07:57 AM
QS's Avatar
QS
skierd:
Yes, thank you Dave...
S AFC will handle it, just needed to know if they would fit "work" on the 1.6L
Old Jan 8, 2003 | 04:02 AM
HEHEHE --- If you asked me the question correctly, I would have given you the right answer...... :-)
It will fit 100% without mods.
