Vendor's Booth: General
Big brake kit
Old Jan 27, 2003 | 08:12 PM
Jon's Avatar
Jon
Default Big brake kit
I have just purchased the big brake kit, can you tell me if there is anything that needs to be modded to fit this on my 99 coupe. Or will it just bolt upto the original mounts and can do the stock brake lines fit as i am looking at getting steel ones but i dont know if these will fit or if they have to be replaced with other ones.
Old Jan 28, 2003 | 01:35 AM
yamaneko's Avatar
That kind of think I have no idea on. YOu might want to post this in the engine modification or suspension forum, im sure someone will know.
Old Jan 28, 2003 | 05:13 AM
2 UNIQ's Avatar
Jon!
I purchased the BB kit over a year ago and the install was very simple and bolted right up?
Since my Tibby is a 97 i had to also change the Hubs because of my car being equipped with Captive Rotors.
Im not sure if you also have the 4 large nuts on your rotor like mine but if so MAKE sure you ordered the kit with the Hubs and Bearings.
Regarding the Brake Lines it will bolt up no no modifications what so ever,so you can order the SS Brake lines from Keystone Auto
Old Jan 28, 2003 | 06:21 AM
Jon's Avatar
Jon
Thanks that helps alot The F2 evo is a wierd car although it was made in 99 its none captive its sort of a cross over car just remove the caliper and the disk comes straight off. I cant wait to get them although the effective area is only just under 1inch bigger that should make hell of a differance. Plus i can paint them before i put them on for a nice finish. I like SR again
Old Jan 28, 2003 | 07:53 AM
SPIKE's Avatar
Old Jan 28, 2003 | 10:41 AM
2 UNIQ's Avatar
Jon:
Your welcome
BTW since you have Non-Captive rotors your install will be very easy and quick.I painted my caliper sBlue before i installed them on my Tibby and looks sweet,BUT after time it will get dirty and will be a pain to clean UNLESS you remove your wheel. smile.gif smile.gif
Old Jan 28, 2003 | 04:05 PM
Jon's Avatar
Jon
Its $535
Old Jan 30, 2003 | 03:18 PM
Moving this topic to Wheel/BRAKES. It will be left here for reference, but It really belongs in that forum.
[ January 30, 2003, 10:21 PM: Message edited by: Random ]
